10-23-2010, 12:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | 7210c dead? 1ST BOOT : C0,07 [Rm-379] [2.1.0.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 2490010F6A4A7F565A1FFF5C3D6445DD394726DC RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : 7310c_RM-379_v9.40_www.**********.com_1_.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x00140000-010DFFFF CMT NOR Erase Area: 0x010E0000-0121FFFF CMT FLASH ERASE OK, Time: 01:23 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x01000400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 01:53 Process Failed, Repowering Mobile what's problem? ANY IDEA thank you |
10-23-2010, 12:21 | #3 (permalink) |
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | see log now : IMAGE : 7310c_RM-379_v9.40_www.**********.com_1_.mcusw ERASE Skipped DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x01004400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 11:40 Process Failed, Repowering Mobile |
10-23-2010, 13:37 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Seems like cable fault, use good 7pin cable or modify it. If your cable is good then Check "Skip Erase" and select only mcu file and flash only mcu part. After mcu flashing Uncheck "Skip Erase" and flash only ppm and cnt part. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-23-2010, 13:47 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: (¯_PAKISTAN_¯)
Member: 491455 Status: Offline Sonork: On My LAB Thanks Meter: 296 | 100% Cable fault. I already face this problem many times. When I replace my cable problem solve |
The Following User Says Thank You to ARS.Rehman For This Useful Post: |
10-23-2010, 15:05 | #7 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | this error DATA_BLK_ERROR at: 0x01004400, 03 mean cable problem try with another one. this is the only option you need and all will be fine good luck |
The Following User Says Thank You to adelkaha25 For This Useful Post: |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
