Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 12-09-2005, 05:33   #1 (permalink)
.::Indian::.'s Avatar
Member: 37015
8360 damaged by HWk..any solution for repaire?
hi all,
I just try for unlock 8360 with HWK and now when i try power on then just blinking.showing charging properly in power off mode. how i can fix it.i full flashed with usbsmart but still showing same problem.ple help me for repaire this phone.
thx
santhosh
Old 12-09-2005, 12:22   #2 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Originally Posted by New GSM
hi all,
thx
santhosh
Flash " FS " at USB Smart then use HWK to FLASH ALL FIRMWARE then unlock it at USB Smart.
Already encountered this with 8330.
BUT LG U8360 Firmware not yet release on www.ufsxhwk.com, try to contact/request Hams to upload the firmware for 8360
Old 12-09-2005, 12:31   #3 (permalink)
Kashif Khan's Avatar
Member: 88016
all devices are working well, but i have no words for SETOOL, setool is better than the best.
Kashif Khan
Old 12-13-2005, 10:11   #4 (permalink)
Member: 37015
hi,
i flashed and unlocked with furious and usb smart.when i flashed and use TP unlock with furious then my phone is power and unlocked but no signal.....any solution for fix it.i flashed v10a and v10e but still no signal.
thx
santhosh
Old 12-13-2005, 10:11   #5 (permalink)
Member: 5926
Kashif Khan
use setool then
no one want to stop you
Rak|m
Old 12-13-2005, 16:59   #6 (permalink)
bad_signal's Avatar
Member: 107069
man i think u have to use the monister called CRUISER tisis the best one for LG3G
in no that
but the HWK is very good tool u have to check the wrong thing u have made it
Old 12-14-2005, 15:39   #7 (permalink)
Member: 37015
in no that
hi,
Right now this movment HWK is not good.i can`t see noting spical in HWK. Now i need solution for repair my lg8360. now phone is power and unlocked but working with only 1 sim(BPL).i used furious and usb smart. how i can fix this problem.
thx
santhosh
Old 12-15-2005, 19:21   #8 (permalink)
Member: 25852
To repair use test point and full flash !
I use vygis for 3g phones and HWK only for sonyericsson !
1 time used HWK for unlock 8120 sw 102 and evrything looks ok all unlocked.
After that no card worked only Insert Correct USIM! on display with orginal card also .
I read phone again and HWK show that phone is unlocked but it was LOCKED EVEN 3G CARD NOT WORKED ANYMORE !
Phone repaired and unlocked with vygis!
downgrade drive c than entered NCK readed by VYGIS .
That was bad expirience cuz customer was waiting and that was my first and time using HWK, maybe i did something wrong but i dont think i unlocked about 200 pcs of LG series 8XXX with vygis and never had problems.
Old 12-16-2005, 04:59   #9 (permalink)
mobileland's Avatar
Member: 22955
Sonork: 67574
in no that
There would be no solution for LG3G if Laser(SETOOL) didn't make it.
You would still only look at the customers when they ask you for unlock, and would tell them I have the best SEMC tool, but don't support those LG phones.
I guess your customers would still like you and your cruiser. )
hehehe
There is no points of making pool about LG3G best solution!!!
Best Regards!
Old 12-17-2005, 07:43   #10 (permalink)
Member: 37015
hi all,
Fixed my lg8360 problem with cracked vygis.thx to all for help.
thx
santhosh
Old 12-17-2005, 07:57   #11 (permalink)
BouRRi_GSM's Avatar
Member: 111457
hi all,
thx
santhosh
of course, it's possible
I need solution for repair damaged EROM Z530i ssseeerrrggg Cruiser Suite 7 02-12-2008 19:09
any solution for damaged phone by ust pro2 hanan_gsm QUALCOMM Models (3G) 4 08-30-2006 21:19
Any Solutions for Repair ribbon cables pls Anahrennik Samsung Hardware Repair Area 0 08-26-2004 17:13
Solution for repair damaged bosch in exchange te Various 3 08-01-2001 18:19
any solution for repair b.nikola Infineon C16X M51 & ARM7 M52 BASED 0 06-09-2000 08:30
Page generated in 0.31622 seconds with 11 queries
