Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 12-09-2009, 06:52   #1 (permalink)
m_tahir1's Avatar
Member: 482214
Sonork: 100.1617896
Question After flash 1209 goes 2 1208
MCU SW : V 5.71 12-09-08 RH-105 (c) NMP
PPM SW : V 5.71 12-09-08 RH-105 (c) NMP IA
Prd.Code: 0550577
Bpr.Code: 0571405
Prod.Sn : DRO037421
HW Vers : 1604
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
DSP Vers: ICPR62_08w31_UPP
LCD Type: TPO:NAXvD6 ST7628
IMEI : 359339-02-XXXXXXX
SL Conf : 001-01-00000000000
SL Prof : 800000000001000-B
SL Var : 00003593390277648100
SL Aux : 000B0000
HW Sig : F5A929E9923FE835
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
The Following 2 Users Say Thank You to m_tahir1 For This Useful Post:
Old 12-09-2009, 06:59   #2 (permalink)
.::CPU_3660::.'s Avatar
Member: 974072
Yes bro because 1208 & 1209 same as a RH-105 and also the flash file of that unit is the same.....
Old 12-09-2009, 07:03   #3 (permalink)
Member: 172261
it's normal... just like 1203 after flash become 1202
Old 12-09-2009, 21:18   #4 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Upload 1209 Product Profile after flash.
Odia.
Old 12-10-2009, 03:22   #5 (permalink)
Member: 172261
where can find Product Profile? or just read pp, write it back after flash?
Old 12-10-2009, 03:51   #6 (permalink)
mbiborna's Avatar
Member: 770503
Odia.
sir i am also try upload this pp file but same it show 1208 why ?
this file originaly read form 1209
File Type: rar 1209 Rh-105 pp.rar (279 Bytes, 196 views)
The Following User Says Thank You to mbiborna For This Useful Post:
Old 12-10-2009, 04:06   #7 (permalink)
transpirit's Avatar
Member: 950964
i have a problem like this i flashed nokia 6234 rn 123 i became 6233 and now shown 6233 y is that its version is not same nokia 6233 is rm145 and nokia 6234 is rm123
Old 12-10-2009, 14:23   #8 (permalink)
Member: 4042
You need to check which bit is for Parallel Product and set it correctly, you can normally get the descriptions from the .vpl files which are infact zip files.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 12-10-2009, 15:35   #9 (permalink)
Nadjombe's Avatar
Member: 185608
Lightbulb No Prob!
Prd.Code: 0550577
Bpr.Code: 0571405
Prod.Sn : DRO037421
HW Vers : 1604
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
SL Aux : 000B0000
What's the difference btwn 1208 and 1209?
Old 12-10-2009, 15:37   #10 (permalink)
Nadjombe's Avatar
Member: 185608
Lightbulb No Prob!
Prd.Code: 0550577
Bpr.Code: 0571405
Prod.Sn : DRO037421
HW Vers : 1604
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
SL Aux : 000B0000
Old 12-10-2009, 17:59   #11 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Sonork: 100.1587814
@ Dear All after flash write this pm 100% tested by me.
note: dont factory rest or ui after this PM.
RH-105_new 1209.rar
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 12-10-2009, 18:06   #12 (permalink)
Member: 355782
Sonork: 100.1587814
Old 12-12-2009, 15:59   #13 (permalink)
Member: 1129038
Bro erase phone then flash again i hope you over come it .
Old 12-12-2009, 21:00   #14 (permalink)
Member: 904530
Erase ?
erase seems is universal solution on everything
after crying about imei, restart, superdongle !
I found this on support:
Root / Nokia_SW/ PM/ RH-105_SET_TO_1209.zip
Root / Nokia_SW/ PM/ RH-105_SET_TO_1208.zip
Old 12-13-2009, 10:21   #15 (permalink)
Member: 4042
Yes use these files from support they are stripped down and have only the required info, Nokia dont use PP method on these phones anymore.
Odia.
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post:
I have k610 dead after flash all goes well Mansoor SETool2 8 02-22-2010 09:10
Page generated in 0.74148 seconds with 12 queries
