12-01-2005, 07:56 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2005 Age: 39
Member: 132334 Status: Offline Sonork: 100.87489 Thanks Meter: 1,193 | Quote:
get the Orignal One | |
12-31-2006, 08:09 | #9 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Inside Blackberry
Member: 288462 Status: Offline Thanks Meter: 87 | I tried to flash D600 but it alway appear these. Hopefully someone can advise me wat to do. Thank u. MCU File: d608zcfh1.cla CheckSum: 9649123D TFS File: d608zcfh1.tfs CheckSum: EDD1BE86 CFG File: d608zcfh1.cfg 92582 byte(s) 1st Boot Failed: Power-Up Regards GFI |
01-06-2007, 16:23 | #13 (permalink) |
No Life Poster Join Date: Jun 2005 Location: in the line of fire..
Member: 157118 Status: Offline Thanks Meter: 156 | ater adding correct flash file.select baud rate 921600.then press write flash.insert D500 rj45 cable into box.then plug in cable into fone,without battery.when fone is detected clip on battery onto fone.sit back,put yr feet up hav a fag and chill.until process finish......... |
01-12-2007, 11:18 | #15 (permalink) | |
Member: 288462 Status: Offline Thanks Meter: 87 | I tried the following but still getting the same result? The phone is a 100% working phone. Does anyone know how to go about flashing the phone? MCU File: d608zcek3.cla CheckSum: 964F2CC6 TFS File: d608zcek3.tfs CheckSum: C656ED71 CFG File: d608zcek3.cfg 90426 byte(s) 1st Boot Failed: Power-Up Quote:
if any body have solution no network found in n70 | chinchik | Nokia Hardware & Hardware Repair | 5 | 01-04-2009 16:42 |
Any body have sendo flashing tool | Tahir Riaz | powerflasher | 1 | 12-31-2008 22:24 |
any body have tested flashing samsung Z500 in hwk | 6800 | HWK | 3 | 12-28-2005 14:43 |
any body have arabic flash for panasonic GD87 | Bido_Elgen | Panasonic | 1 | 01-07-2005 07:48 |
Does any body have all the preset ringtones of Nokia 7210 in midi format? | kingofhearts | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 05-18-2003 02:21 |
