03-02-2011, 10:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | b5722 error during flash here is log MCU File: B5722DDJA1_Master.cla CRC32: FDAA9B29 TFS File: B5722DDJA1_Master.tfs CRC32: B498DF72 CFG File: B5722DDJA1_Master.cfg 191900 byte(s) MCU File: B5722DDJA1_Slave.clas CRC32: 417A5A3D TFS File: B5722DDJA1_Slave.tfs CRC32: 03821B7F CFG File: B5722DDJA1_Slave.cfg 1164 byte(s) Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:10 File CRC: 0xFDAA9B29 MCU Write Done, 30807140 byte(s), Time: 08:13 File CRC: 0xB498DF72 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 207 Max_Files : 2309 Files_Count: 2309/2309 TFS Unmounted TFS Write Done, 40536642 byte(s), Time: 14:42 Slave 1st Boot Failed: FATAL_ERROR, Recovering |
03-02-2011, 13:16 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | If you are flashing with battery In then take out battery and if you flashing without battery then insert battery. Wr. |
03-02-2011, 14:44 | #3 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | this is with battery ma previous log was without battery here is MCU File: B5722DDJA1_Master.cla CRC32: FDAA9B29 TFS File: B5722DDJA1_Master.tfs CRC32: B498DF72 CFG File: B5722DDJA1_Master.cfg 191900 byte(s) MCU File: B5722DDJA1_Slave.clas CRC32: 417A5A3D TFS File: B5722DDJA1_Slave.tfs CRC32: 03821B7F CFG File: B5722DDJA1_Slave.cfg 1164 byte(s) Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:09 File CRC: 0xFDAA9B29 MCU Write Done, 30807140 byte(s), Time: 08:27 File CRC: 0xB498DF72 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 207 Max_Files : 2309 Files_Count: 2309/2309 TFS Unmounted TFS Write Done, 40536642 byte(s), Time: 14:56 --- SLAVE --- Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] Erase Done, 7 sector(s), Time: 00:02 Slave MCU MSL Patched Ok, Time: 00:23 File CRC: 0x5E98C9E9 MCU Write Done, 7276100 byte(s), Time: 04:12 File CRC: 0x03821B7F TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 20 Max_Files : 9 Files_Count: 9/9 Files Closed TFS Unmounted TFS Write Done, 198871 byte(s), Time: 00:12 Connect Cable to Switched Off Mobile (with battery) Sign Firmware Failed: |
03-03-2011, 10:28 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Wr. | |
03-03-2011, 10:34 | #7 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | after complete flashing now its went to the blinking here is log MCU File: B5722DDJA1_Master.cla CRC32: FDAA9B29 TFS File: B5722DDJA1_Master.tfs CRC32: B498DF72 CFG File: B5722DDJA1_Master.cfg 191900 byte(s) MCU File: B5722DDJA1_Slave.clas CRC32: 417A5A3D TFS File: B5722DDJA1_Slave.tfs CRC32: 03821B7F CFG File: B5722DDJA1_Slave.cfg 1164 byte(s) Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:10 File CRC: 0xFDAA9B29 MCU Write Done, 30807140 byte(s), Time: 08:16 File CRC: 0xB498DF72 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 207 Max_Files : 2309 Files_Count: 2309/2309 TFS Unmounted TFS Write Done, 40536642 byte(s), Time: 14:40 --- SLAVE --- Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] Erase Done, 7 sector(s), Time: 00:02 Slave MCU MSL Patched Ok, Time: 00:35 File CRC: 0x5E98C9E9 MCU Write Done, 7276100 byte(s), Time: 04:11 File CRC: 0x03821B7F TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 20 Max_Files : 9 Files_Count: 9/9 Files Closed TFS Unmounted TFS Write Done, 198871 byte(s), Time: 00:12 Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 Firmware Signed Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 Firmware Already Signed ! Sign Failed: Check Connect Cable to Switched Off Mobile (with battery) Sign Firmware Failed: Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 Firmware Already Signed ! Sign Failed: Check Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 Firmware Already Signed ! Sign Failed: Check |
03-03-2011, 13:13 | #8 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | STILL ON BLINKING WITH ANOTHER FILE HERE IS LOG MCU File: B5722XXJK3_Master.cla CRC32: 872A54DC TFS File: B5722XXJK3_Master.tfs CRC32: E843D574 CFG File: B5722XXJK3_Master.cfg 190443 byte(s) MCU File: B5722XXJK3_Slave.clas CRC32: 63E18FA8 TFS File: B5722XXJK3_Slave.tfs CRC32: 03812417 CFG File: B5722XXJK3_Slave.cfg 1005 byte(s) Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:10 File CRC: 0x872A54DC MCU Write Done, 31231228 byte(s), Time: 08:30 File CRC: 0xE843D574 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 199 Max_Files : 2290 Files_Count: 2290/2290 TFS Unmounted TFS Write Done, 31037611 byte(s), Time: 12:27 --- SLAVE --- Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] Erase Done, 7 sector(s), Time: 00:02 Slave MCU MSL Patched Ok, Time: 00:22 File CRC: 0xD4C23B54 MCU Write Done, 7276900 byte(s), Time: 04:10 File CRC: 0x03812417 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 18 Max_Files : 5 Files_Count: 5/5 Files Closed TFS Unmounted TFS Write Done, 177170 byte(s), Time: 00:11 Connect Cable to Switched Off Mobile (with battery) Sign Firmware Failed: CSC File: CRC32: 00000000 Regions : Estonia,Kazakhstan,Latvia,Lithuania,Russia,Ukraine Language: en,et,lt,lv,ru,uk(az,bg,de,fr,hy,ka,kk,mk,ro,sr) Release : 2010 November Rev: 1 CCF File: B5722OXEJK1.ccf 28096 byte(s) Connect Cable to Switched Off Mobile (with battery) Sign Firmware Failed: Connect Cable to Switched Off Mobile (with battery) BBID: 99B6593810 Firmware Signed |
03-05-2011, 14:42 | #10 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | Software: B5722XXJK3 Hardware: MP 0.601 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2010 November Rev: 3 MSL Active S/N : RQQZ927479 IMEI: 35xxxxxxxxxxxxxxxxxxx BTID: FCA1:3E:1E5561 MSL Active SIMLOCK STATUS: 0000 MCC-MNC: MASTER KEY: 52530030 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 --- SLAVE INFO --- Software: B5722XXJK3 Hardware: MP 0.601 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2010 November Rev: 3 MSL Active MSL Deactivated S/N : RQQZ927479 IMEI: 358577-03-941876-4 Flags: 00000000 [Not Locked] Key M: 00000000 [MASTER] Prov : 000-000 Key 1: 00000000, 00000000 Key 2: 00000000, 00000000 Key 3: 00000000, 00000000 Key 4: 00000000, 00000000 Key 5: 00000000, 00000000 Key 6: 00000000, 00000000 Key 7: 00000000, 00000000 |
03-05-2011, 17:09 | #11 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Info looks ok, backup current Master and Slave E2P and flash a full image, if you cannot find a full image trying flashing just E2P with some good ones, if that does not help then it must be hardware. Odia. |
04-11-2012, 12:47 | #13 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Udalguri, ASSAM
Member: 300547 Status: Offline Thanks Meter: 23 | 100% Flashing SAMSUNG B5772 BY UFS MCU File: B5722DDJA1_Master.cla CRC32: FDAA9B29 TFS File: B5722DDJA1_Master.tfs CRC32: B498DF72 CFG File: B5722DDJA1_Master.cfg 191900 byte(s) CSC File: B5722ODDJA1.csc CRC32: 0B1EB0C6 CCF File: B5722ODDJA1.ccf 21050 byte(s) MCU File: B5722DDJA1_Slave.clas CRC32: 417A5A3D TFS File: B5722DDJA1_Slave.tfs CRC32: 03821B7F CFG File: B5722DDJA1_Slave.cfg 1164 byte(s) BBID: 05C7564EA6 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:09 File CRC: 0xFDAA9B29 MCU Write Done, 30807140 byte(s), Time: 07:52 File CRC: 0xB498DF72 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 207 Max_Files : 2309 Files_Count: 2309/2309 TFS Unmounted TFS Write Done, 40536642 byte(s), Time: 14:21 CSC Format Done, Time: 00:00 File CRC: 0x0B1EB0C6 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 39 Max_Files : 240 Files_Count: 240/240 CSC Unmounted CSC Write Done, 5120349 byte(s), Time: 01:32 --- SLAVE --- Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] Erase Done, 7 sector(s), Time: 00:02 Slave MCU MSL Patched Ok, Time: 00:09 File CRC: 0x5E98C9E9 MCU Write Done, 7276100 byte(s), Time: 04:03 File CRC: 0x03821B7F TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 20 Max_Files : 9 Files_Count: 9/9 Files Closed TFS Unmounted TFS Write Done, 198871 byte(s), Time: 00:12 Sign Firmware Failed: Enter Boot Error Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Master E2P File: B5722_358576-03-xxxxxx-6_MASTER_E2P.bin BBID: 05C7564EA6 MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] E2P IMEI Patched Ok: 3xxxxx-xx-xxxxx-x File CRC: 0x64BF3634 E2P Write Done, 2097152 byte(s), Time: 00:32 Slave E2P File: B5722_3xxxx-xx-xxxxxx-x_SLAVE_E2P.bin --- SLAVE --- Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] Slave E2P IMEI Patched Ok: 3XXXXX-XX-XXXXX-6 File CRC: 0x2E40F207 E2P Write Done, 524288 byte(s), Time: 00:18 FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering Sign Firmware Failed: Enter Boot Error FATAL_ERROR, Recovering BBID: 05C7564EA6 Firmware Signed FIRST ERASE FLASH MASTER AND SLAVE THEN WRITE MASTER E2P AND SLAVE E2P WITH IMEI TRY SIGN FW WITHOUT BATTERY. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
