04-22-2008, 00:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: In Your Room Age: 47
Member: 97299 Status: Offline Thanks Meter: 43 | box auth 33 allredy tray with an new update same error . b.r. |
04-23-2008, 11:55 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | you can uninstall and reinstall the software as many times are you like, but it will not fix your UFS box auth issue, for that, you can check the 1000+ other posts on the subject, or chose the easy option and read the sticky thread. Odia. |
04-23-2008, 23:03 | #6 (permalink) | |
Member: 97299 Status: Offline Thanks Meter: 43 | Quote:
that mean i need to contact my resseler ? the one dit not make bussines over 1 year what solt o do now ? | |
04-24-2008, 09:27 | #7 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 614026 Status: Offline Thanks Meter: 20 | How to upgrade successfully to 2_07 Follow step by step, don't skip. 1. Make sure the HWK module is upgraded to the latest by HWK update client 207, Unplug ur UFS_HWK box 2. Uninstall previous HWK suite and HWK support suite 3. Extract and Run SarasSoft_Emergency_Cleanup 4. Install HWK_Support_Suite_Setup_v02.07.000, confirm to install USB drivers (if asked to), do not run HWK Update Client yet. 5. Plug in your UFSx box to install USB drivers (v3.1.5.0) 6. Run HWK Update Client. Click 'Next', wait some time - you should see UFSx/HWK serial numbers in the HWK Update Client log window. 7. Now click on 'Quit' (do not update your HWK again) 8. Import attached 'HWK_207_2ndPC.reg' file into your Registry (extract the rar file, and double-click the extracted file, 'Yes' to overwrite) 9. Install HWK_Suite_Setup_v02.07.00. It should work. |
The Following User Says Thank You to wee2000 For This Useful Post: |
04-24-2008, 10:43 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | What's problam my HWK pls any one help me Upgrade log: ---------- HWK Update Client v 2.0.7.0 ---------- ---------- HWK upgrade started:3:24:34 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 133428 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-FBAA9C9241600048 -- HWK Status : 1, DL: 8 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:Account for this HWK module does not exist on server. Please contact your reseller! |
04-24-2008, 18:01 | #9 (permalink) | |
Junior Member Join Date: Apr 2008
Member: 743742 Status: Offline Thanks Meter: 0 | Quote:
Account for this HWK module does not exist on server. Please contact your reseller! | |
05-18-2008, 07:33 | #11 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | Upgrade log: ---------- HWK Update Client v 2.0.7.0 ---------- ---------- HWK upgrade started:11:15:42 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 103677 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ID : A1.04-PRO1-14xx6F********* -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. i hv also faced that kind of problem plz help me Last edited by GsmMunna; 05-18-2008 at 08:08. |
@@@@@ Infinity box Pinfinder 33 cable set with image @@@@@ | yogesh_prj | Infinity-Box | 8 | 03-13-2010 16:13 |
ET-BoX v1.33 Released - May 12th 2007 - Support for Spice Flash ID : DA13 | .:ET-BoX.net:. | ET-BoX | 7 | 05-13-2007 14:29 |
