c1-01 after flash local mode only before i flash phone is working i checked hardware is ok |
no br i checked 2 handsets same problem |
i think local,test mode problem is only hardware not software |
br;) |
try to flash by higher ver.......ur problem 100% solve....... |
c1-01 local mode 100%%%% solution Quote:
flash phone with 4.30 ver 100% solv your problem may be hardware showthis http://forum.gsmhosting.com/vbb/f148...nside-1306416/ |
flash with higher version my tested solution........ |
c1-01 Quote:
Which cable are you using it BR, |
i had same ,problem,,but solved by,,changing sw version,,,check it..flash with 4.40.. and post result |
flash with 4.40 verson probelem solve |
