09-29-2009, 08:36 | #2 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Only ptt file you can flash that but connot down load a file from suport because the server is offline |
The Following User Says Thank You to lilong_lee For This Useful Post: |
11-14-2009, 11:44 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | mobile flashed but still rebooting on startup logo Code: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: llcoolr HID: llcoolr HWK: A1.04-PRO1 Licence: True Loaded Settings from: Sams.ini PROD_ID: 91A70A19A6 SCROM_V: PNX5220 V.06.01 CHIPSET: 3811 FLLDR_V: 7.0.7 FL_CHIP: K9F1G08Q0M BOOT Ok, 921600 Baud NAND Read Done, 3145728 byte(s), Time: 00:52 E2P Saved as C:\Program Files\SarasSoft\UFS\UFS_SAMs\L700\L700_91A70A19A6_E2P.bif Partition Table: l700_jp_comp.ptt BAD_NAME: L700_JP_Comp.ptt PROD_ID: 91A70A19A6 SCROM_V: PNX5220 V.06.01 CHIPSET: 3811 FLLDR_V: 7.0.7 FL_CHIP: K9F1G08Q0M BOOT Ok, 921600 Baud Partition IMAGE_BMP Erase Done, 2 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition IMAGE_IMG Erase Done, 2 block(s), Time: 00:00 Partition MAIN Erase Done, 176 block(s), Time: 00:10 Partition PAGED Erase Done, 104 block(s), Time: 00:06 Partition LFS Erase Done, 144 block(s), Time: 00:08 Partition FS Erase Done, 402 block(s), Time: 00:24 Partition DB Erase Done, 128 block(s), Time: 00:07 Partition IMAGE_BMP Write Done, 116214 bytes(s), Time: 00:02 Partition LCDACT Write Done, 4688 bytes(s), Time: 00:00 Partition IMAGE_IMG Write Done, 77440 bytes(s), Time: 00:01 Partition MAIN Write Done, 21859488 bytes(s), Time: 06:11 Partition PAGED Write Done, 13330176 bytes(s), Time: 03:46 Partition LFS Write Done, 15711904 bytes(s), Time: 04:27 Partition FS Write Done, 54337536 bytes(s), Time: 15:53 Partition DB Write Done, 17301504 bytes(s), Time: 05:03 Partition BOOTNAND Write Done, 131072 bytes(s), Time: 00:02 |
11-14-2009, 12:23 | #8 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | also I've found eeprom file in support area but could not be written with soft Cos an error occurred say "wrong file selected !" when selecting "L700.ts_eep" need help !!! |
11-25-2009, 03:30 | #11 (permalink) | |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
this problem only solve for hwk flash with the latest ptt ,firmware it is not an eeprom problem i think your flash file select to flash that may be not accepted that's why the phone is same problem flash with the latest firmware the if same post here logs with best regards: Lilong lee | |
04-06-2010, 20:55 | #12 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Partap Mobile Point, Jalandhar
Member: 1088851 Status: Offline Thanks Meter: 17 | Here is flashing logs, phone flashed two times with diffrent-2 files but same prb..... UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 59980 HID: EE11924D012700DD HWK: A1.04-PRO1 Licence: True LogFile: .\_!_LOG\59980_46201070_437_LOG.txt Loaded Settings from: Sams.ini Partition Table: L700DXHH4_Open_SEAsia_All_Comp.ptt Regions : Indonesia,Java,Malaysia,Singapore,Thailand,Vietnam Language: en,id,jv,ms,th,vi,zh(ta) Release : 2008 August Rev: 4 PROD_ID: 2B24841912 SCROM_V: PNX5220 V.06.01 CHIPSET: 3811 FLLDR_V: 7.0.7 FL_CHIP: K9F1G08Q0M BOOT Ok, 921600 Baud Partition IMAGE_BMP Erase Done, 2 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition IMAGE_IMG Erase Done, 2 block(s), Time: 00:00 Partition MAIN Erase Done, 176 block(s), Time: 00:08 Partition PAGED Erase Done, 104 block(s), Time: 00:05 Partition LFS Erase Done, 152 block(s), Time: 00:07 Partition FS Erase Done, 402 block(s), Time: 00:19 Partition DB Erase Done, 128 block(s), Time: 00:06 Partition IMAGE_BMP Write Done, 116216 bytes(s), Time: 00:02 Partition LCDACT Write Done, 4688 bytes(s), Time: 00:00 Partition IMAGE_IMG Write Done, 77440 bytes(s), Time: 00:01 Partition MAIN Write Done, 22298960 bytes(s), Time: 06:19 Partition PAGED Write Done, 13340648 bytes(s), Time: 03:43 Partition LFS Write Done, 19252334 bytes(s), Time: 05:22 Partition FS Write Done, 54337536 bytes(s), Time: 16:42 Partition DB Write Done, 17301504 bytes(s), Time: 05:18 Partition BOOTNAND Write Done, 131072 bytes(s), Time: 00:02 |
04-07-2010, 04:56 | #13 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
readed especially for you L700_0DE02CF123_E2P.rar | |
05-01-2011, 15:46 | #15 (permalink) | |
Registered User Join Date: Apr 2008 Location: Goyang City
Member: 751390 Status: Offline Thanks Meter: 18 | Quote: how we can write eeprom brother?? just look at for this model,, ++++++++++++++++++++++++++++++++++++ i have same problem, but it can not write flash.... COME IN,, | |
L700 hang on Samsung Logo Done W/ Z3x | rhedhead_21 | Z3X-Team Products | 3 | 03-18-2015 09:38 |
how to flash a SGH-Z240 | Frenzy_2020 | Samsung Flashers, Software, Firmware. | 10 | 10-24-2009 14:29 |
samsung sgh-x820 hang on logo | shashankmobile | UST Pro II | 3 | 05-28-2009 09:43 |
Samsung Sgh-e300 freezed on Samung logo | AirSac | UST Pro II | 1 | 05-27-2007 13:19 |
How to flash V200 which not power on | unlockmax | Trident/AGERE Platform | 4 | 02-21-2004 15:06 |
