09-01-2010, 07:02 | #4 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | Try to flas but i have slave 1 boot failed here is log: MCU File: C5212XDIK1_Master.cla CRC32: 82FFB20B TFS File: C5212XDIK1_Master.tfs CRC32: DD683931 CFG File: C5212XDIK1_Master.cfg 145843 byte(s) MCU File: C5212XDIK1_Slave.cla CRC32: BD3C3595 TFS File: C5212XDIK1_Slave.tfs CRC32: 03812417 CFG File: C5212XDIK1_Slave.cfg 1005 byte(s) MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M (1G NAND) NAND Format Complete, Time: 00:11 File CRC: 0x82FFB20B MCU Write Done, 27582712 byte(s), Time: 07:20 File CRC: 0xDD683931 TFS Version : TFS4.0_CORONA_01 Directories : 147 Max_Files : 1799 Directory : /a Directory : /a/bt Directory : /a/bt/bpp Directory : /a/bt/bpp/icon Directory : /a/bt/bpp/temp Directory : /a/bt/bpp/template Directory : /a/customer Directory : /a/customer/nvmgr Directory : /a/db Directory : /a/fileviewer Directory : /a/font Directory : /a/images Directory : /a/images/anim Directory : /a/images/brightness Directory : /a/images/calculator Directory : /a/images/call Directory : /a/images/call/black Directory : /a/images/call/black/set01 Directory : /a/images/call/black/set02 Directory : /a/images/charging Directory : /a/images/charging/5level Directory : /a/images/email Directory : /a/images/fm Directory : /a/images/fm/unified player Directory : /a/images/graphicCli Directory : /a/images/graphicCli/full_skin Directory : /a/images/graphicCli/full_skin/callerid Directory : /a/images/graphicCli/full_skin/speeddial Directory : /a/images/graphicCli/speeddial Directory : /a/images/graphicCli/speeddial/skin01 Directory : /a/images/graphicCli/speeddial/skin02 Directory : /a/images/hwratio Directory : /a/images/idle Directory : /a/images/idle/menu Directory : /a/images/jimage Directory : /a/images/keyvolume Directory : /a/images/keyvolume/volume15 Directory : /a/images/menu Directory : /a/images/menu/theme1 Directory : /a/images/menu/theme2 Directory : /a/images/menu/theme3 Directory : /a/images/message Directory : /a/images/mms Directory : /a/images/mtp Directory : /a/images/mtp/ucs Directory : /a/images/org Directory : /a/images/org/set01 Directory : /a/images/org/set02 ....( to large size of log, I resize it)... File: /c/Sounds/Melody05.mid, Size: 7408 TFS Unmounted TFS Write Done, 30105088 byte(s), Time: 12:14 Slave 1st Boot Failed: |
09-01-2010, 07:07 | #5 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | When I try flash only slave flash I have log: MCU File: C5212XDIK1_Slave.cla CRC32: BD3C3595 TFS File: C5212XDIK1_Slave.tfs CRC32: 03812417 CFG File: C5212XDIK1_Slave.cfg 1005 byte(s) 1st Boot Failed: |
09-01-2010, 09:00 | #6 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
09-01-2010, 18:44 | #7 (permalink) | |
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote:
here is log : MCU File: C5212XDIC2_Master.cla CRC32: D278ED80 TFS File: C5212XDIC2_Master.tfs CRC32: 7F2EBB0A CFG File: C5212XDIC2_Master.cfg 145824 byte(s) MCU File: C5212XDIC2_Slave.cla CRC32: 094BAC72 TFS File: C5212XDIC2_Slave.tfs CRC32: 03812417 CFG File: C5212XDIC2_Slave.cfg 1005 byte(s) Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M (1G NAND) NAND Format Complete, Time: 00:11 File CRC: 0xD278ED80 MCU Write Done, 27571904 byte(s), Time: 07:13 File CRC: 0x7F2EBB0A TFS Version : TFS4.0_CORONA_01 Directories : 147 Max_Files : 1798 Directory : /a Directory : /a/bt Directory : /a/bt/bpp Directory : /a/bt/bpp/icon Directory : /a/bt/bpp/temp Directory : /a/bt/bpp/template ..... (to large log then i resize it) File: /b/java/java_Embd/suites.utf, Size: 517 File: /b/java/_main.ks, Size: 7067 File: /b/java/_policy.txt, Size: 3322 File: /b/java/alarmlist.txt, Size: 0 File: /b/java/manager_storage_settings.db, Size: 109 File: /b/java/pushlist.txt, Size: 0 File: /b/mms/template/1.pre, Size: 3093 File: /b/mms/template/10, Size: 87794 File: /b/mms/template/11, Size: 105161 File: /b/mms/template/12, Size: 81613 File: /b/mms/template/13, Size: 131612 File: /b/mms/template/14, Size: 79393 File: /b/mms/template/2, Size: 80572 File: /b/mms/template/3, Size: 167245 File: /b/mms/template/4, Size: 169216 File: /b/mms/template/5, Size: 180517 File: /b/mms/template/6, Size: 127955 File: /b/mms/template/7, Size: 189226 File: /b/mms/template/8, Size: 209800 File: /b/mms/template/9, Size: 230370 File: /b/vobject/vnote_dummy_file.df, Size: 409600 File: /b/vobject/vnote_manage.vm, Size: 7212 File: /b/vobject/vnote_mng_backup.bak, Size: 7212 File: /c/Music/Beyond Samsung.mp3, Size: 3117874 File: /c/Sounds/Melody01.mid, Size: 8439 File: /c/Sounds/Melody02.mid, Size: 17520 File: /c/Sounds/Melody03.mid, Size: 17655 File: /c/Sounds/Melody04.mid, Size: 5398 File: /c/Sounds/Melody05.mid, Size: 7408 TFS Unmounted TFS Write Done, 30094240 byte(s), Time: 12:34 --- SLAVE --- Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC240200010000E1D0, Samsung 128M NOR Erase Done, 7 sector(s), Time: 00:02 File CRC: 0x094BAC72 MCU Write Done, 14321940 byte(s), Time: 03:52 File CRC: 0x03812417 TFS Version : TFS4.0_CORONA_01 Directories : 18 Max_Files : 5 Directory : /drm Directory : /drm/temp Directory : /mms Directory : /mms/camera Directory : /mms/camera/image Directory : /mms/camera/thumb Directory : /mms/draft Directory : /mms/inbox Directory : /mms/myfolder Directory : /mms/outbox Directory : /mms/owtest Directory : /mms/temp Directory : /mms/template Directory : /mms/updwload Directory : /netinfoset Directory : /test Directory : /udb Directory : /vobject Files_Count: 5/5 File: /test/cfg.txt, Size: 954 File: /udb/PTI_udb.dat, Size: 8192 File: /vobject/vnote_dummy_file.df, Size: 153600 File: /vobject/vnote_manage.vm, Size: 7212 File: /vobject/vnote_mng_backup.bak, Size: 7212 Files Closed TFS Unmounted TFS Write Done, 177170 byte(s), Time: 00:13 When I put , 2 other sim cards, phone have only one network, but not active sim card when i try to call, " no network" any solution ? | |
09-02-2010, 09:10 | #11 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | HERE IS LOG in mobile info Software: C5212XDIC2 Hardware: REV1.0 Regions : Czech,Hungary,Poland,Slovakia Language: cs,de,en,fr,hu,it,pl,sk(hr) Release : 2009 March Rev: 2 MSL Active MSL Deactivated S/N : RP4S611641 IMEI: 352832xxxxxxx-4 BTID: 0012:47:000001 Flags: 00000000 [Not Locked] Key M: 00000000 [MASTER] Prov : 000-000 Key 1: 00000000, 00000000 Key 2: 00000000, 00000000 Key 3: 00000000, 00000000 Key 4: 00000000, 00000000 Key 5: 00000000, 00000000 Key 6: 00000000, 00000000 Key 7: 00000000, 00000000 SIMLOCK STATUS: 0000 MCC-MNC: 000-000 MASTER KEY: 00000000 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 --- SLAVE INFO --- Software: C5212XDIC2 Hardware: MP 0.600 Regions : Czech,Hungary,Poland,Slovakia Language: cs,de,en,fr,hu,it,pl,sk(hr) Release : 2009 March Rev: 2 MSL Active MSL Deactivated S/N : RP4S611641 IMEI: 352833-xxxxxxxx-2 Flags: 00000000 [Not Locked] Key M: 00000000 [MASTER] Prov : 000-000 Key 1: 00000000, 00000000 Key 2: 00000000, 00000000 Key 3: 00000000, 00000000 Key 4: 00000000, 00000000 Key 5: 00000000, 00000000 Key 6: 00000000, 00000000 Key 7: 00000000, 00000000 SIMLOCK STATUS: 0000 MCC-MNC: 000-000 MASTER KEY: 00000000 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
