Check Product, Use newer Flash Update Pack IF YOU HAVE ANY SOLUTION ....... 1st Boot: Ok, DCT4, UPP: 2201 [Dte-1] [2.0.8.0] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x01FFFFFF,588882D9, UNKNOWN CHIP ! FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Update Pack Algorithm: u_intel.fia, Ver: 4.76.0 Rebooting Mobile WHAT SHALL I DO HELP |
thats problem is flash IC, change good ic sir.. Did you do backup for that sir? if you dont? change also uem sir. good luck. |
fia problem use jaf fia inside odeon/flash then overwrite your phoenix flash folder. |
this is 100% uem problame change it and write rpl all will be ok |
brother first click as same model then click check after is same rehot cpu |
idont think it is cpu or uem because the same on other working 2 mobiles i think ufs suit problem. |
u r correct i agree with u 1100 old model i try to flash unable but jaf i suceed |
That 100% ufs flash loader problem, fix flash in phoenix with new update (or get ur new flash file nokia with setup--->just install) or update ur ufs. |
problem fixed 100% thanks |
hello can you uploand here the flash update ? thanks.... |
