Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 10-29-2008, 19:12   #1 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 782
Thumbs up Check Product, Use newer Flash Update Pack
IF YOU HAVE ANY SOLUTION .......
1st Boot: Ok, DCT4, UPP: 2201 [Dte-1] [2.0.8.0]
2nd Boot: u_2nd.fia, Ver: 4.76.0
Fl0: 0x01000000-0x01FFFFFF,588882D9, UNKNOWN CHIP !
FLASH DEVICE NOT SUPPORTED
Algorithm: u_intel.fia, Ver: 4.76.0
Rebooting Mobile
WHAT SHALL I DO
HELP
Old 10-29-2008, 19:15   #2 (permalink)
ticksjarub's Avatar
Member: 534932
Thanks Meter: 49
thats problem is flash IC, change good ic sir..
Did you do backup for that sir? if you dont? change also uem sir.
good luck.
Old 10-29-2008, 23:35   #3 (permalink)
Member: 167930
Thanks Meter: 5
fia problem use jaf fia inside odeon/flash then overwrite your phoenix flash folder.
Old 10-30-2008, 05:05   #4 (permalink)
madho's Avatar
Member: 647592
Thanks Meter: 186
this is 100% uem problame change it and write rpl all will be ok
Old 10-30-2008, 05:58   #5 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
Thanks Meter: 183
brother first click as same model then click check after is same rehot cpu
Old 10-30-2008, 06:29   #6 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 782
good luck.
first all thank you for your best respect
idont think it is cpu or uem
because the same on other working 2 mobiles
i think ufs suit problem.
Old 10-30-2008, 12:06   #7 (permalink)
ashok_kumar459's Avatar
Member: 202500
Thanks Meter: 222
u r correct i agree with u 1100 old model i try to flash unable but jaf i suceed
Old 10-30-2008, 22:22   #8 (permalink)
Member: 641419
That 100% ufs flash loader problem, fix flash in phoenix with new update (or get ur new flash file nokia with setup--->just install) or update ur ufs.
Old 10-31-2008, 17:23   #9 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 782
both of you are right
problem fixed 100%
thanks
Old 12-11-2008, 22:02   #10 (permalink)
Member: 263901
Thanks Meter: 2
hello
can you uploand here the flash update ?
thanks....
The Following User Says Thank You to klodbrace For This Useful Post:
e55,e52..Check Product, Use newer Flash Loader Pack zandoo Nokia Base Band 5 ( BB-5 ) 5 11-15-2011 10:31
.:hack3r2k:. plz check when i try to update pack 5 this error come rajan nishchal FuriousGold 8 02-26-2009 08:52
Use newer Flash Update Pack turca HWK 3 12-11-2008 00:06
Need newer Flash Update Pack nzeiga HWK 2 03-30-2008 23:03
flash update pack need!! mirko Griffin 2 06-17-2004 08:56
Page generated in 0.45273 seconds with 8 queries
