04-28-2008, 22:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Dublin
Member: 746630 Status: Offline Thanks Meter: 23 | DCT4 flash problem on HWK 1st Boot Err: Bad Resp DCT3, C3 D3 5 Cannot Detect Mobile Brand 1st Boot: Ok, DCT4, UPP: 1130 [Rh-30] 2nd Boot: u_2nd.fia, Ver: 4.69.0 Fl0: 0x01000000-0x017FFFFF,00EC22FA,Sam K8S6415ETA Algorithm: u_amd.fia, Ver: 4.69.0 Algorithm Ok, MSID: 849160A7CD723863AFD65882C3 Decoded MSID: D3EBBAE9-0056847A-AA000000 Encoded FAID: AF62FECB-59E7B26F-4F0118B6 IMAGE: rh3010_05.34a Area1: 0x01580000-0x0168FFFF Erased, Time: 00:11 MCU Flashing Completed, Time: 00:06 IMAGE: rh3010_05.34b Area1: 0x01580000-0x0168FFFF Erased, Time: 00:11 PPM Flashing Completed, Time: 00:06 Flashing Completed, Rebooting Mobile UI Defaults Failed |
04-29-2008, 09:46 | #5 (permalink) |
Member: 746630 Status: Offline Thanks Meter: 23 | Everyone thanks, Now I put as MCU rh3010pra05.340, and as PPM rh3010_05.34e, how could I recognise CNT file? ANYWAY doesn't work I mean can't flash, geting that masage: 1st Boot Err: Bad Resp DCT3, 00 93 5 Cannot Detect Mobile Brand 1st Boot Err: Bad Resp UPP, 03 00 00 72 Process Failed, Repowering Mobile WHAT AM I DOING WRONG? |
04-29-2008, 10:44 | #6 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | mcu = rh3010pra05.340 ppm = rh3010_05.34e (as you said) cnt = rh3010_05.34.ucp_e (normally we put same as ppm) you can't boot it cos i think you click [START], it wont work if phone can't power on just click [FLASH] |
04-29-2008, 11:56 | #8 (permalink) | |
Member: 746630 Status: Offline Thanks Meter: 23 | Quote:
1st Boot Err: Bad Resp UPP, 03 00 00 72 Process Failed, Repowering Mobile Same I got with nokia 1101 I've tried to flash with diferent cable??? | |
04-29-2008, 12:34 | #9 (permalink) |
Member: 746630 Status: Offline Thanks Meter: 23 | That I have tried to flash nokia1101 RH 75 mobile is NOT dead working perfect only I want to change the language: Detected: V 3.05 15-05-05 RH-75 (c) NMP 1st Boot Err: Bad Resp UPP, 03 00 00 72 Process Failed, Repowering Mobile Scenario "flash" Interface "F bus" speed "normal" Auto clear result "checked", auto scrol result window " checked", autodetect product "cheked" Product " RH75 (1101) " MCU -rh75_05.040, PPM-rh75_05.04eh, Skip erise form area "9", CNT Auto "checked", BT hw "auto" Anything I have to add or remove??? Thank you everyone for your help |
04-29-2008, 14:33 | #10 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
This says that Phone WAS Dead Before Flashing And I Not See CNT Flashing, Only rh3010_05.34a as MCU rh3010_05.34b as PPM So Selected 2x Different PPM Files instead MCU, PPM and CNT files ... May Need To Select MCU -> rh3010pra05.340 PPM -> rh3010_05.34a CNT -> rh3010_05.34.ucp_a Munna. | |
3120C Flashing problem on HWK | kasamiko | HWK | 7 | 09-11-2009 08:30 |
BB5 flashing problem on HWK | GsmSolution | HWK | 30 | 06-08-2008 22:13 |
dct3 and dctl problem on hwk! | CuLo | HWK | 3 | 05-26-2008 11:01 |
Problem on HWK | moni_bm | HWK | 3 | 05-13-2007 09:39 |
new problem on HWK | panafax_gsm | HWK | 4 | 08-14-2005 20:43 |
