Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2004 Location: ALGERIA W09
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks: 34
| DCTxBB5 TOOLS v 2.0.5.1 HWK HELP killed my 6230i aftre try to change lang and now phone is dead Detected: V 03.80 31-Mar-06 RM-72 GSM P1.1 (c) NMP. 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256 Algorithm: te_amd_b.fia, Ver: 4.61.0 Algorithm Ok, MSID: 84CD8FD3F563ABDD6109D8E9E8 Decoded MSID: 91DFBAE9-009D0F3E-A8000000 Encoded FAID: 73C762DD-3B8C2EA8-9FFA6A39 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x009FFFFF Erased, Time: 01:24 Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:10 Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:36 MCU Flashing Completed, Time: 00:54 FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND] 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256 Algorithm: te_essr.fia, Ver: 4.61.0 Warning: Must be Used File for OneNAND Chips (M) Erasing Mass Memory Erasing Error: MM_2B_2, Time: 00:10 Process Failed, Repowering Mobile Last edited by llcoolr; 05-13-2007 at 17:34. Reason: thanks for replay |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: Hungary :D Age: 28
Member: 176830 Status: Offline Thanks: 1
| read this: flash 6230i or 6230i problem help plz or search : http://forum.gsmhosting.com/vbb/sear...rchid=18273211 many solution for you and this isnt bug |
| | #4 (permalink) |
| Moderator ![]() Join Date: Aug 2004 Location: .:: 36MY1EH ::.
Member: 79937 Status: Offline Sonork: 100.84313 Thanks: 7
| what flash files you use? it can be problem of flash files too if u selected wrong flash files as it is shown that u have to use M type flash files. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: Bada
Member: 206476 Status: Offline Thanks: 53
| Oi this is the secrit "TIKU EIJA SSR [NAND]" there is 2 type on 6230i so plz change the PPM and cnt file and you will alive yor phone it's not bug |
| | #6 (permalink) |
| @freeman2001 this is the secrit "TIKU EIJA SSR [NAND]" there is 2 type on 6230i so plz change the PPM and cnt file and you will alive yor phone it's not bug i changed firmware many times and still same thing ? wich version i sould use @.::Rizwan::. where to find M type flash files PLZ HELP ODIA |
| The Following User Says Thank You to llcoolr For This Useful Post: |
| | #10 (permalink) |
| problem solved THANK U rm72_73_11003.620 rm72_73_110M_03.62g rm72_73_110M_03.62.ucp_g 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256 Algorithm: te_amd_b.fia, Ver: 4.61.0 Algorithm Ok, MSID: 845F2647E116DF9CB74122CF7F Decoded MSID: B03FBAE9-009D0F3E-A9000000 Encoded FAID: 2A0BEC2E-B19B8657-115F18DA Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x009FFFFF Erased, Time: 01:25 Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:10 Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:37 MCU Flashing Completed, Time: 00:54 FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND] 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256 Algorithm: te_oncsm.fia, Ver: 4.61.0 Mass Memory Erased, Time: 00:01 CNT Flashing Completed, Time: 00:26 Running: Nokia File Server Contents Package Extracting Ok, Time: 00:22 FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND] 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256 Algorithm: te_oncsm.fia, Ver: 4.61.0 Mass Memory Erased, Time: 00:00 PPM Flashing Completed, Time: 00:29 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:25 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 IMEI: 353364-00-145464-7, ASIC: 6 SimLocks Initialized (NM Ok), Time: 00:00 All Done, Time: 05:57 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Dctxbb5 tools v.2.0.8.0 error | mkwatis | UFS2 + UFS3-Tornadoflasher | 1 | 05-01-2009 20:46 |
| 6630 with 2.0.5.3 hwk help | chitawira | HWK | 0 | 06-08-2007 09:36 |
| Need Ufs Setup 2.0.5.1 | denard | HWK | 0 | 05-12-2007 10:41 |
