Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 01-20-2008, 15:26   #1 (permalink)
f164's Avatar
Member: 184351
e250 after flashing it no ringtone
i have one samsung e250 it has a problem in its camera after flashing it the phone works normally and the camera too but it does not ring and the signal is so week and somtimes no signal any solution for this problem
Old 01-20-2008, 15:37   #2 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
dear frends phone is samsung e250D NOW DOWNOAD FLASH FROM SAMSUNG E250D FLASH PHONE MCU AND TFS AFTER FLASH WITH THIS FLASH FILE FOR E250D NOW RESET PHONE WITH CODE *2767*3855# AND ALL WIL BE OK .
BR.DELCHONI
Old 01-20-2008, 15:37   #3 (permalink)
Member: 146708
Sonork: 100.108221
hi..
did u try to write eeprom .? eeprom files on the support.. if u cant find i can add for u..and i have full back up from working phone.. if u want i can add them.. mcu and tfc nd eeprm..
Old 01-20-2008, 16:31   #4 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Originally Posted by just_learn View Post
hi..
eeprom only will not help ,u will have to erase the whole flash(nor<nand,eeprom) then flash with the correct firmware version+write e250d eeprom
Old 01-20-2008, 16:52   #5 (permalink)
Member: 146708
Sonork: 100.108221
yes sir..
if phone is e250d ur precedure is right..
Old 01-20-2008, 16:52   #6 (permalink)
f164's Avatar
Member: 184351
before flashing the phone i read the eprom can i use it
Old 01-20-2008, 17:56   #7 (permalink)
f164's Avatar
Member: 184351
phone back to normal state after following these steps: make nor erase ,make nand erase , write e2p readed before from the phone,
write E250DXEGK1.cla as mcu file write ,write E250DXEGK1.tfs as tfs file, eprom full reset, but the camera is not working properly when you want to take a photo it starts blinking but for video it is working normally where is the problem?
Old 03-28-2008, 23:44   #8 (permalink)
Member: 543291
I HAVE THE SAME PROBLEM. AFTER FLASHING NO RINGTONES AND THE PHONE IS LOOSING SIGNAL AND CAN'T CALL IN OR OUT.
Old 03-29-2008, 13:07   #9 (permalink)
Member: 543291
Problem is solved !Just flashed with e250d files and after full reset via code which is provided and the phone now is working perfect !
Old 06-29-2008, 12:11   #10 (permalink)
gulab_sam's Avatar
Member: 759661
a have e250 no ring pls help me friends no riding on track
Old 06-30-2008, 10:37   #11 (permalink)
Member: 198907
there is 2 diffrent phone if your board is green you can flash it
if your board is blue better flash the original firmware and leave it like that
before the phone wont powered on
Old 06-30-2008, 10:48   #12 (permalink)
Member: 388002
write eeprom e250d then full flash e250d flash filse then full reset
regards
Old 06-30-2008, 13:24   #13 (permalink)
Member: 481337
Just make full reset (*2767*3855#) after flashing E250/E250D and everything will be OK with the ringtones.
If you flash with wrong software, there will be no network coverage.
So be careful when you flash E250 or E250D.
Old 06-30-2008, 13:39   #14 (permalink)
Member: 625817
Sonork: 1592120
i face same proplem
when i fixed sound and cam another proplem face me when i make a call no sound of call
pleas where the trick????
e250 after flash no earpiece sound and signal problem kavikumaran UST Pro II 3 03-08-2010 09:45
e250 after flash no hearing and no mic adaki_vishal Z3X-Team Products 6 02-25-2010 14:08
Samsung e250 after flash no network help? webzone136 NSPRO 4 10-07-2008 09:46
E250 After Flash No Display irfanamin2 UST Pro II 6 03-06-2008 22:43
Page generated in 2.24856 seconds with 11 queries
