Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-21-2009, 07:13   #1 (permalink)
Member: 424066
Thanks Meter: 43
ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF:
1ST BOOT : C0,0C [Rm-84] [2.0.9.0]
OMAP ID : 17100701
OMAP MODE : 00
OMAP PBID : 12AF76EC3FFEF0975F3D2DBDA83B72CCDA4009F3
OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
OMAP ROID : AB5E4ADB27A06946
RAPx ID : 000000010000022600010006000C192101002200
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx PBID : 01200102F9B94F51F8A41A32328206A125D8E819
RAPx MODE : 00
RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
RAPx ROID : F28A211FCEA7B19D
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
00000090: 00 00 ..
Rebooting Mobile
ps help me sir how to slove this problem thanks
The Following 5 Users Say Thank You to prem2007 For This Useful Post:
Old 08-21-2009, 22:44   #2 (permalink)
Member: 507911
Thanks Meter: 22
try to uncheck dual line and 1331 option first !!! if not working use blank ape method find the solution in the hardware repair section
The Following 5 Users Say Thank You to juwana_pati For This Useful Post:
Old 08-22-2009, 05:23   #3 (permalink)
Member: 424066
Thanks Meter: 43
hello
i had try to uncheck dual line and 1331 option but same problem but i had try to check jaf software but not err:app ps help me sir
Old 08-22-2009, 11:00   #4 (permalink)
Member: 189015
Thanks Meter: 9
hello
you must conect rx2
change the cable
flash him with n70+j cable (6 pin)
Old 08-22-2009, 13:14   #5 (permalink)
Member: 424066
Thanks Meter: 43
hello
thanks brother i had try to check 6pin cable working perfect very nice
Old 09-02-2009, 04:56   #6 (permalink)
abheejeet's Avatar
Member: 811063
Thanks Meter: 203
hello friend if u cheng keypad ic plz remove keypad ic andchek phone it is key pad ic problem or http://rapidshare.com/files/274127874/n_70_ape.ace.html
The Following 2 Users Say Thank You to abheejeet For This Useful Post:
Old 09-02-2009, 05:43   #7 (permalink)
Member: 424066
Thanks Meter: 43
hello friend i had not change keypaid ic i didnot understand what did you say i have no problebm i had only change n70+j (6 pin) cable my problem is go out
Old 10-23-2009, 15:50   #8 (permalink)
Member: 1102630
Thumbs up try to uncheck dual line and 1331 option first !!! if not working use blank ape metho
thnx bro it worked for my n72
Old 11-07-2009, 13:06   #9 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
its omap error. change omap
Old 02-07-2010, 08:56   #10 (permalink)
Member: 495465
Thanks Meter: 12
n72
it's ok
Old 05-04-2010, 11:55   #11 (permalink)
Member: 890856
Thanks Meter: 135
use 7pin cable..........
Old 05-05-2010, 05:51   #12 (permalink)
sandhu36's Avatar
Member: 387696
Thanks Meter: 161
bro not cabel problm solve this tested
http://forum.gsmhosting.com/vbb/f299...-100-a-980216/
Old 05-17-2010, 18:48   #13 (permalink)
Member: 1162710
Sonork: azeem.sr 100.1626141
Thanks Meter: 8
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
00000090: 00 00 ..
Rebooting Mobile
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
00000090: 00 00 ..
Rebooting Mobile
The Following User Says Thank You to azeem.sr For This Useful Post:
Old 07-01-2010, 20:40   #14 (permalink)
Member: 1244325
Cool
Originally Posted by electro12 View Post
hello
you must conect rx2
change the cable
Sir, can you please attach this image how to do that, thanks in advance
Old 07-24-2010, 13:26   #15 (permalink)
Member: 31665
Thanks Meter: 4
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
00000090: 00 00 ..
Rebooting Mobile
use another cable bro, problem wil solved. i tested in many phones !!!!
The Following User Says Thank You to speeth For This Useful Post:
N95 Flash problem > ERR: APE 2ND Boot APE 2ND ACK bhgsmservis HWK 11 07-02-2013 16:42
ERR: APE 2ND Boot FLB_MSG_C2: APE 2ND CONF No Info outlandier Nokia Hardware & Hardware Repair 8 04-26-2012 05:27
ERR: APE 2ND Boot APE 2ND ACK ..:: Mobile Clinic™ ::.. HWK 5 11-14-2011 12:30
plz help n70 dead ERR: APE 2nd Boot zahed1978 Nokia Base Band 5 ( BB-5 ) 1 11-01-2011 13:31
N70 ERR: APE 2nd Boot FbusMsg llcoolr HWK 5 09-06-2007 09:51
Page generated in 0.25605 seconds with 11 queries
