03-25-2010, 23:30 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | SWIFT-AEROFONE A137,CC01i,E1070C,E1100C,E1101C,E1107,E1113C,E1120 C,E1210, E1310C,E1310E,E1360,E1360C,E1360S,E2100C,E2210C,E2 210H added (DUNL,IM,FL) E1080,E1080C,E1080T,E1085,E1085L,E1085T,E1088C,E1100H,E1150, E1150C,E1160,E2120,E2120B,E2120C,E2130 added (CUNL,FL) Odia. |
03-26-2010, 14:42 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | Be clear sir! You answer but not solve my problem!I need a solution not an answer. Unlock done but still locked...It means i must fullflash the phone or what? Please i need the SOLUTION not update word! |
03-27-2010, 14:29 | #9 (permalink) |
Member: 185608 Status: Offline Thanks Meter: 592 | Yes in right way!But have done it with no success. Otherwise i unlock it by self search and with HWK. So problem solved and thank to all!!!!!!!!!! |
03-27-2010, 14:46 | #10 (permalink) |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | No need for fullflash, e2p flash and similar bsht .... - make full reset: *2767*3855# - Unlock E2P (or Read E2P then Chk E2P File) (Sorry, didn't read carefully, already solved out) |
05-24-2010, 09:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2008 Location: VIZAG,A.P,๑۩INDIA&
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | i have same problem E1085T unlocking done but still locked i tryed unlock and unlockE2P and chk E2P file but same problem pls help me . |
05-24-2010, 13:35 | #13 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 870664 Status: Offline Sonork: 100.1614707 Thanks Meter: 56 | 1- make full reset: *2767*3855# 2- Unlock E2P if code not shown make the same steps good luck because when making unlock e2p this will not unlock your phone but it will show ya your codes here is an example i've made 10 minutes ago it's E1080i Connect Cable to Switched Off Mobile (with battery) Preloader Ok 06, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N3217ATA [NOR 32Mb] MCU Read Done, 524288 byte(s), Time: 00:07, 0 E2P Info: IMEI: 359243-03-298211-1 REG.FIRMWARE: E1080iSVJB1 Extended: SIMLOCK STATUS: 0009 MCC-MNC: 208-01 MASTER: 74111160 #SIMLOCK*NET*13639740# #SIMLOCK*SUB*00000000# #SIMLOCK*SP*46577470# #SIMLOCK*CP*00000000# E2P Saved as C:\Program Files\SarasSoft\UFS\UFS_SAMs\Read\E1080_359243-03-298211-1_E2P.bin |
E1085T unlocked flash file! | Nadjombe | SWIFT Platform | 3 | 04-07-2011 13:14 |
GT e1085t unlock done | robba | UST Pro II | 2 | 05-01-2010 17:08 |
GT-E1085T unlocking[Solved] | viniicell | SPT BOX | 4 | 02-08-2010 12:48 |
unlocking LG-cg225 | cellrepairus | NSPRO | 0 | 04-30-2008 22:37 |
