Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 03-13-2012, 21:49   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
M2520 dead after flash
I have phone freeze in logo, after flash no power, battery is full Help-me
Region: 1, 0x20000000-0x20000063, Length: 100 bytes
Region: 2, 0x2000C000-0x200113FF, Length: 21504 bytes
Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes
Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes
Region: 5, 0x2003803C-0x20041287, Length: 37452 bytes
Region: 6, 0x20058000-0x20058037, Length: 56 bytes
Region: 7, 0x20058138-0x2005C34F, Length: 16920 bytes
Region: 8, 0x20078000-0x2018D987, Length: 1137032 bytes
Region: 9, 0x20300000-0x21EE3FF7, Length: 29245432 bytes
1st:
1st:
1st Boot Ok, McuId: 00050026, Rom: 00050026, 13-1.2 (Vision X113E)
2nd Boot Ok, McuId: 00050026, Rom: 00050026, 7-2.0
Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre
Flash1: Fl_Id: 00890000_887E0000 - Intel SIBLEY 512
Baud Rate Set: 460800 bps
MCU File: CODE_M2520VIIH3_H3.s3
Flashing NOR part...
Write Done, 30484768 byte(s), Time: 18:39
CTS File: CSC_M2520ZVVIH4_H3.csc
FS Formated (FDI)
FS Mounted (FDI)
Files Count: 112
FS Unmounted
FS Write Done, 12150232 byte(s), Time: 07:10
MSL Repair Canceled
Old 03-14-2012, 04:58   #2 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
1st:
1st:
FS Formated (FDI)
FS Mounted (FDI)
Files Count: 112
FS Unmounted
MSL Repair Canceled
try with full erase before flash. and post result
B,R-chamisrilanka
Old 03-14-2012, 19:04   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Change the firmware,and flash the phone with right varient.
Br.
Vijendra Saini.
Old 03-14-2012, 22:52   #4 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
I make but dead only 2 flash in support i make 2 files no work
Old 03-15-2012, 02:47   #5 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
select model m2510 and flashing like m2510 after use this flash of m2520 normal.
flash it again using the model M2510.
Old 03-15-2012, 03:07   #6 (permalink)
Asia_Phone's Avatar
Member: 1300241
Sonork: 100.1626973
Thanks Meter: 356
flash i r again then Pacth MSL
then after Pact MSL Check IMEI if 00000 Rebuild it.
Hope it help.
Old 03-15-2012, 18:17   #7 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
Hope it help.
Friend that does not have to do because no calls, I had already tried several times, but thanks
Old 03-15-2012, 18:26   #8 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
Using MSL S/N: RSAZ109559
1st:
1st:
Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:08, 0
Warning, bad NVMD_SIZ: FFFFFFFF
Failed to Enter TEST Mode
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
Page generated in 0.17975 seconds with 9 queries
