03-02-2010, 14:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | error in flashing HERE IS LOG 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 840260A9F99D24554424AD3237 Decoded MSID: 3E4EBAE9-0087CE55-A8000000 Encoded FAID: FD75C222-80B0FB9E-3BD55203 IMAGE: rh105_05.910 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:37 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:19 IMAGE: rh1050_nai5.91ia Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
03-02-2010, 16:19 | #2 (permalink) |
Junior Member Join Date: Feb 2009 Location: hyderabad,India
Member: 981175 Status: Offline Thanks Meter: 3 | extracting contents package failed (dct-4) this problem is phone not entering into local mode. the problem could be with -BSI series resistor inside the cable is low value( should be 5.1k) -Hold the power button of phone when extracting contents package msg appears. - Could be the problem of Flash Chip ( reball it or replace it.) Check & post result. |
03-02-2010, 17:51 | #3 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
use easy cable or disable vpp pin from fbus cable (use search option) | |
03-02-2010, 18:16 | #4 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
3k3 is right for bsi line mostly like these problums erease is best solution otherwise cable problum hardware is last option br, | |
k550 flash done but show a error in flashing | Master Software | SETool2 | 2 | 02-09-2010 09:59 |
problem in mx-key error in flash | FEATURE GSM™ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-30-2009 09:23 |
L7 in Blank Mode but Error in Flashing... | jhox2 | Motorola P2k | 8 | 11-14-2008 05:56 |
rm-320 n95 8gb not in model list and error in flashing | chiragp | MT-BOX | 17 | 12-09-2007 04:14 |
Error in flashing A50? | unicos | x1x to x45/x50 | 0 | 07-24-2003 07:26 |
