01-05-2009, 16:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: EARTH
Member: 359939 Status: Offline Sonork: none Thanks Meter: 61 | error installing HWK suite 02.07.00 "install not authorised please download an insatall HWK support suite and update with latest client and retry main install 02.07.00" |
01-05-2009, 16:28 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Nov 2007
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | Quote:
Update your HWK: good luck | |
01-05-2009, 17:05 | #3 (permalink) | |
1 - uninstalled all previous versions and all driver for box Then 2 - remove this : hwkkiller.dll ufsloader.dll Ufs2xx.dll ufs2xx.sys from C:\******\system32 3 - Install HWK_Support_Suite_Setup_v02.08.000.exe you can download from her (dont insert box now) 4 - after install the suppoet suite setup use this 5 - install HWK_Setup_Suite_v02.08.000.exe you can downlod from her 6 - now install box C:\Program Files\SarasSoft\UFS\UFS_USB_Driver 7 - reinstall HWK_Setup_Suite_v02.08.000.exe chose ( Repair ) 8 - if update your box and all well be OK update after 48H good luck.. | |
01-05-2009, 17:12 | #4 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
Munna. | |
need help hwk update ok but cannot install hwk suite | kapospalad | HWK | 0 | 10-03-2008 08:40 |
Problem To Install Hwk Suite Setup V02.07.00 | volamihamina | HWK | 6 | 04-21-2008 20:19 |
Problem installing last update 02.07 hwk | hridaya | HWK | 13 | 03-24-2008 18:17 |
can't install HWK suite HWK suite v02.0600 | maxwell owusu | HWK | 2 | 11-23-2007 03:27 |
Install HWK Suite 2.05.007 and upgrade ur HWK keys... HWK server is working now.. | Arif Jamil | HWK | 9 | 10-08-2007 21:17 |
