05-13-2009, 16:59 | #1 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: nepal
Member: 977789 Status: Offline Thanks Meter: 4 | error in nokia 3110 ui setting it only called failed i tried with jaf but cant get solution plz anybody help me its urgent |
05-14-2009, 06:36 | #3 (permalink) |
Member: 977789 Status: Offline Thanks Meter: 4 | ui setting error in 3110 1ST BOOT : C0,07 [Rm-237] [2.0.8.4] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0A60021576467D560DB487225638DEBC75888B85 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898981-00006A21, Int NU48F256 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.33.1 CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__06.01.ppm_mr CMT NOR Erase Area: 0x01080000-0151FFFF PPM FLASH ERASE OK, Time: 00:21 PPM FLASH WRITE OK, Time: 00:22 Flashing Completed, Rebooting Mobile |
05-14-2009, 07:10 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Btw, did u flashed mcu and cnt? I can see only ppm here Br, Shadab Ahmad Last edited by [Shadab_M]; 05-14-2009 at 07:18. | |
05-14-2009, 07:18 | #6 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
.................................................. ................... if ur set is ON and only not doing factory setting then its mean set not comming in Test mode use proper cable prolem will be ok | |
05-14-2009, 09:52 | #9 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | i also faces such a problems espacially in 3110c u cant even reset the user code without comming in test mode 6300 and 3110c cable is same in shape but there is some change inside it mean some resistance change we commonly use 6300 cable for 3110c we dont use proper cable thats why set not comming in test mode there is no way to format it manual format by button is not supported in this model just arrange proper cable it will format in just 3 seconds |
05-14-2009, 10:45 | #11 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | Quote:
7pin cable and ext:vpp 7.5k resistance you must be use ...............your set 100% flash % ui seting compleat tested without problem.......... B.r. TUR@nALAM | |
Nokia 3100 UI setting failed | zakir375 | Nokia Hardware & Hardware Repair | 2 | 11-21-2007 19:43 |
3650 SUCCESS IN FLASHING but UI setting filed | ali_9 | WD2 & APE (Symbian Phones) | 6 | 03-18-2007 19:37 |
nokia 7210 ui setting problum | gomi555 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-13-2006 15:54 |
nokia 3350 ui setting factory defaul error please help. | Raimond | Nokia Hardware & Hardware Repair | 2 | 09-01-2005 10:01 |
Nokia tools UI setting not working for 3210!!! | hooi76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-07-2002 12:26 |
