04-08-2010, 12:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Help for flashing SE Z520 and problem comunication... I have problem for connection with SE Z520,i use the cable usb converter com 4 in 1 UniUSB box by unlockers is compatible with HWK?You can have the cable drivers? thanks, BR. |
04-08-2010, 13:22 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | 9v battery ? this is for what ? use original USB cable ! hold C and connect cable select USB and press boot |
The Following User Says Thank You to Major-T For This Useful Post: |
04-08-2010, 13:52 | #5 (permalink) | |
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
Hi Before i have flashing with SEUS and aborted ,after with HWK error cert help me plese i think erom damaged or file flash no compatible mbn and fbn? UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: xxxxxxxxxxxxx HID: xxxxxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True, 00010 Log File: DBX_REPORT_LOG.log, created USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 Ini File: Z520_36R.ini Created NBOOT_CERT ERR_01: No Resp SHUT DOWN FL ... USB Closed USB Closed USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 Nothing to Flash NBOOT_CERT ERR_01: No Resp Flashing Failed, 00001 SHUT DOWN FL ... | |
04-08-2010, 20:39 | #7 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | i have flashed with file .bin all ok the flashing but not not work and will not turn on the phone,ment Maybe I did flash with different cxc? I have flashing wit this file: X_Z520_CXC1123021_NAM1_R3C035.bin X_Z520_CXC1250151_EUROPE-5_R3J017.bin the support does not have the same main + fs cxc,erom and gdfs how can I solve? thanks, BR. log : UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: xxxxxxxx HID: xxxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True, 00010 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 info gdfs : P_LOAD : 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB FLSH_ID: 890D [Intel 38F4x50LxYT] P_LOAD : 041110 0957 GOHCXC1327364_COMPACT_SEMC_CS_LOADER_R2C CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ FINISH CS ... USB Closed |
04-08-2010, 22:16 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Use KZF it has move features to fix this phone. Odia. |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
04-09-2010, 12:00 | #9 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | Thanks Mr.Odia the best programmer HWK suite is very best always update withouot bugs!!! return to the phone with the USB cable original does not terminate the flash usb communication error,with the 4 in 1 cable and with RJ 45 into the box not boot and does not recognize the phone why? BR. |
04-09-2010, 12:21 | #10 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | Screen with cable rj into box and cable 4 in 1 seam problem may be that the com port does not match? how do I know which com port with the working box? BR. |
04-09-2010, 12:52 | #11 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | the mobile phone recognized only usb cable original without info firmware ,etc UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: xxxxxxxxxxx HID: xxxxxxxxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True, 00010 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : FID ERR_01: No Resp USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : FID ERR_01: No Resp |
04-09-2010, 13:53 | #12 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | after charging battery full flash completed But do not function only turns the three keys and power button # 9 not info firmware in the booting UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: XXXXXXX HID: XXXXXXXXXXXXXXXXXX HWK: A1.04-PRO1 Licence: True, 00010 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : FID ERR_01: No Resp USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : FID ERR_01: No Resp USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 P_LOAD : 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB IMAGE : Z520_R3J017_FS_EUROPE_5_RED36.fbn FLSH_ID: 890D [Intel 38F4x50LxYT] WRITTEN: 146 Block(s), 00237 Flashing Done, 00238 SHUT DOWN FL ... USB Closed USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 P_LOAD : 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB IMAGE : Z520_R3J017_MAIN_EU_1_ZB_RED36.mbn FLSH_ID: 890D [Intel 38F4x50LxYT] WRITTEN: 287 Block(s), 00505 Flashing Done, 00505 SHUT DOWN FL ... USB Closed USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 BR. |
04-09-2010, 20:52 | #13 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | afer full charching battery I think that the log is correct I have to finalize correct?I can not see the support files to customize,please someone shows me where to find them? BR. UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: xxxxxx HID: xxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True, 00010 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 U_LOCK : 0000 CXC_NR : cxc1250151 R3J017 CDA_NR : |
04-09-2010, 21:37 | #14 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | I redid the full flash but the custom crashes when going to write to the file system i think gdfs damaged... thanks for help, BR. |
04-10-2010, 12:31 | #15 (permalink) |
Member: 217461 Status: Offline Thanks Meter: 150 | HI , i think gdfs ok and customize ok UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: xxxxxxxxxxxx HID: xxxxxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True, 00010 USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 U_LOCK : 0000 CXC_NR : cxc1250151 R3J017 CDA_NR : CDA102337/13 R6A P_LOAD : 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB FLSH_ID: 890D [Intel 38F4x50LxYT] P_LOAD : 041110 0957 GOHCXC1327364_COMPACT_SEMC_CS_LOADER_R2C CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ CANNOT READ FINISH CS ... USB Closed USB Opened MCU_ID : 80400301FFFFFFFF P_LOAD : 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L FLSH_ID: 890D [Intel 38F4x50LxYT] M_CERT : 36 RED IMEI : 358339-00-023906-0 CD_PAF : 1 0 1 OTPCID : 36 RED CID_UP : 3636 GDFS_INIT : 00 (OK) GDFS 0-006: 00 00000000: DE 8F 26 32 73 0A 8E 36 1D EF 5C 3B 97 6B 55 0C ..&2s..6..\;.kU. 00000010: E4 03 D6 8C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000020: FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000040: 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF ................ 00000050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 000000A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 ................ 000000B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000000C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000000D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000000E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000000F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000001A0: 00 00 00 00 00 00 00 00 00 00 .......... GDFS 0-00E: 00 00000000: A9 0D 12 45 59 19 3F 8E 6F ED 57 02 FB 3F 4E 71 ...EY.?.o.W..?Nq 00000010: E6 E2 99 7D 00 00 00 00 55 1E 00 01 00 1E 00 00 ...}....U....... 00000020: 55 55 1E 00 01 00 1E 00 00 55 55 1E 00 01 00 1E UU.......UU..... 00000030: 00 00 55 55 1E 00 01 00 1E 00 00 55 55 1E 00 01 ..UU.......UU... 00000040: 00 1E 00 00 55 55 1E 00 01 00 1E 00 00 55 00 FF ....UU.......U.. 00000050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000060: 00 04 00 00 00 00 00 00 00 00 .......... GDFS 0-013: 00 00000000: 89 84 D4 CF 8C D9 AE DB 59 E3 84 38 14 E7 BD DB ........Y..8.... 00000010: 0C 60 CC CD 14 80 C3 77 05 20 D6 05 05 01 05 02 .`.....w. ...... 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 72 C5 20 C0 54 15 38 76 92 3E F3 54 ....r. .T.8v.>.T 00000040: DE 39 5D 38 EF 13 2E 3A 9D 38 26 8E EF 36 EB 7B .9]8...:.8&..6.{ 00000050: 8F 89 56 BC 5F 58 2E 0F 60 50 E9 5E 43 59 C1 55 ..V._X..`P.^CY.U 00000060: 6D CD EE 4F BB 07 9A 02 79 5B 99 1F CB D5 77 BB m..O....y[....w. 00000070: 27 3A A6 02 C8 A2 F0 67 05 AC 10 07 41 D6 2D AB ':.....g....A.-. 00000080: D6 EB 7C E8 11 B3 85 A6 16 1C D1 67 58 5B 4A 1D ..|........gX[J. 00000090: 85 19 0B 18 0F CB 41 77 34 84 79 A8 9B 79 F7 5A ......Aw4.y..y.Z 000000A0: E6 01 1D 77 54 DE 7C 90 4B 06 28 59 41 13 85 0F ...wT.|.K.(YA... 000000B0: 1F CE A5 B5 C4 73 70 C4 E8 79 6B BA B9 41 A1 E5 .....sp..yk..A.. 000000C0: C8 95 A7 7B CF 49 3B 2A BC A0 3D E3 84 57 2C DE ...{.I;*..=..W,. 000000D0: 9F CF F2 97 53 0E FB B6 6C B1 88 28 15 1D 42 BB ....S...l..(..B. 000000E0: F3 30 5B A5 35 02 D8 E7 BC F0 C1 8E 5A 1C 4E B0 .0[.5.......Z.N. 000000F0: 75 16 08 0B FC F6 E6 F7 38 83 A6 E0 27 BD 8C F5 u.......8...'... 00000100: C1 D4 93 8A 8B 0F C4 73 AA C0 C4 00 3A AC 62 26 .......s....:.b& 00000110: 13 E9 32 E8 42 F7 A4 E5 78 09 9A 7A 4F A1 6B 03 ..2.B...x..zO.k. 00000120: 01 8C 08 18 .... GDFS 2-CE9: 00 00000000: 52 33 4A 30 31 37 20 20 20 20 20 20 70 72 67 43 R3J017 prgC 00000010: 58 43 31 32 35 30 31 34 33 5F 45 55 5F 31 5F 5A XC1250143_EU_1_Z 00000020: 42 00 52 33 4A 30 31 37 00 0A 2A 2A 2A 20 54 69 B.R3J017..*** Ti 00000030: 6D 65 me GDFS 2-CEA: 00 00000000: 52 33 4A 30 31 37 00 0A 2A 2A 2A 20 54 69 6D 65 R3J017..*** Time 00000010: 72 3A 20 55 73 69 6E 67 20 6F 6C 64 20 74 69 6D r: Using old tim 00000020: 65 72 20 66 75 6E 63 74 69 6F 6E 20 53 65 74 4F er function SetO 00000030: 6E 65 ne GDFS 2-CBC: 00 00000000: 43 44 41 31 30 32 33 33 37 2F 31 33 00 00 00 00 CDA102337/13.... 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000020: 00 00 00 ... GDFS 2-CBD: 00 00000000: 52 36 41 00 00 00 00 00 00 00 00 00 00 00 00 00 R6A............. 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 ............. GDFS 2-CBE: 00 00000000: 63 78 63 31 32 35 30 31 35 31 00 00 00 00 00 00 cxc1250151...... 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000020: 00 00 00 ... GDFS 2-CBF: 00 00000000: 52 33 4A 30 31 37 00 00 00 00 00 00 00 00 00 00 R3J017.......... 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 ............. U_LOCK : 0000 CXC_NR : cxc1250151 R3J017 CDA_NR : CDA102337/13 R6A |
T29s need help for flashing and flash file | Repair4u | Old Ericsson Phones & Sony Phones | 1 | 04-19-2009 00:49 |
help during flashing of z520 cid36 and w300i | belli42 | Sony Ericsson Hardware Repair | 0 | 12-14-2008 23:03 |
please please i need help for flashing error 303106 k750 and W800 | gsm4libya | SonyEricsson (USB-Smart) | 4 | 01-01-2006 03:08 |
SE Z520 flashin problem. | tumovil | SonyEricsson (USB-Smart) | 0 | 12-12-2005 21:09 |
HELP !!! I flashed Sony J5 and have a problem | roller | Sony | 2 | 03-29-2002 16:00 |
