Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Saras Boxes > HWK
Old 05-14-2010, 16:02   #1 (permalink)
Member: 205776
Help Me. How to flash Samsung B3313?
How to flash Samsung B3313? Only MDL is there in "DOCS". No flash files. Then how to flash?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 05-14-2010, 21:44   #2 (permalink)
vijendrasaini's Avatar
Member: 398557
Sonork: 100.1578489
Just wait for while i copied a firmware from ON handset ill upload here tommorow.
Br.
Vijendra Saini.
Old 05-14-2010, 21:54   #3 (permalink)
Member: 904530
B3313 is same as B3310, only different firmware
Old 05-18-2010, 13:46   #4 (permalink)
romeoluv56's Avatar
Member: 1170910
which cable need to flash or copy flash from working phone ?
Old 12-04-2010, 06:43   #5 (permalink)
Member: 275643
dear u r not moderator but ur work is so good that i like to see u as a moderator of sarasoft specially in samsung.
Old 12-04-2010, 06:55   #6 (permalink)
choclate_'s Avatar
Member: 1323797
Sonork: 100.1596855
for see cable saw cable name front of model.
Old 12-04-2010, 06:58   #7 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1611891
who want to help update this model then if you have z3x do contact me
Old 12-04-2010, 07:00   #8 (permalink)
choclate_'s Avatar
Member: 1323797
Sonork: 100.1596855
use micro usb cable and for flash insert batrry and dont power on mobile just select file and press write flash than insert usb cable to mobile
BR.inocent
Old 07-20-2011, 15:07   #9 (permalink)
Member: 644473
ur wrong first u put the batt in mobile select file an usb an press * button
and put usb cable 100% succsess
Old 07-20-2011, 17:29   #10 (permalink)
Member: 1473716
Samsung B3310 is also known as Samsung B3313 Corby Mate
http://tsar3000.com/Joomla/index.php...w-to&Itemid=84
Flashing Steps:
1. Run Samsung B3310 Downloader.
2. Select Customer T: Nox (Intel Sibley 1024/256, USB).
3. In Flash Option section check: Code Binary and CSC Binary(Default).
4. Also check this Option: Erase all Unused Regions.
5. Connect the phone in Download mode: Press * and connect USB cable to phone.
6. Now select the Com Port that the phone takes.
7. Select the S3 Flash file and CSC file too, each in his field.
8. Click on Flash button and type YES in the message box then click OK to Start the process.
9. Do not touch or remove the cable till the Program tell you: All is Well.
10. Turn On the phone and do full reset by the code: *2767*3855#.
Old 12-13-2011, 09:47   #11 (permalink)
Member: 325517
Thanks
Originally Posted by gile@gile View Post
samsung b3310 is also known as samsung b3313 corby mate
http://tsar3000.com/joomla/index.php...w-to&itemid=84
flashing steps:
1. Run samsung b3310 downloader.
2. Select customer t: Nox (intel sibley 1024/256, usb).
3. In flash option section check: Code binary and csc binary(default).
4. Also check this option: Erase all unused regions.
5. Connect the phone in download mode: Press * and connect usb cable to phone.
6. Now select the com port that the phone takes.
7. Select the s3 flash file and csc file too, each in his field.
8. Click on flash button and type yes in the message box then click ok to start the process.
9. Do not touch or remove the cable till the program tell you: All is well.
10. Turn on the phone and do full reset by the code: *2767*3855#.
thanksssssssssssssssssssssssss bro
Old 02-17-2012, 13:24   #12 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
How To Update Firmware Of Samsung B3310
Flashing Steps:
When I opne Flasher asking me password. What is password brother?
B.R.,
B.Uttam
Old 02-17-2012, 19:14   #13 (permalink)
Member: 523972
Sonork: 100.1596548
Hello, Samsung B3313 Corby. Blink... I flash with HWK But flashing failed. Now Hadnset dead. Not connecting with HWk & Z3X. How to recover it.
Please share solution Here.
B.R.,
B.Uttam
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 03-21-2012 09:38
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 12-03-2010 06:02
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 0.65594 seconds with 11 queries
