09-09-2012, 15:55 | #17 (permalink) |
No Life Poster Join Date: Dec 2011 Location: GPG India
Member: 1702670 Status: Offline Sonork: 100.1623908 Thanks Meter: 1,667 | use only ufx box not any downloader press * key than plug usb cable select file and select port thanx flash =) simple RAJA SOFT INDORE |
09-19-2013, 14:49 | #19 (permalink) |
Major Poster Join Date: Apr 2008
Member: 742687 Status: Offline Sonork: sunilbansal Thanks Meter: 21 | lashing steps: 1. Run samsung b3310 downloader. 2. Select customer t: Nox (intel sibley 1024/256, usb). 3. In flash option section check: Code binary and csc binary(default). 4. Also check this option: Erase all unused regions. 5. Connect the phone in download mode: Press * and connect usb cable to phone. 6. Now select the com port that the phone takes. 7. Select the s3 flash file and csc file too, each in his field. 8. Click on flash button and type yes in the message box then click ok to start the process. 9. Do not touch or remove the cable till the program tell you: All is well. 10. Turn on the phone and do full reset by the code: *2767*3855#. |
03-02-2014, 06:50 | #20 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Aligarh ,India Age: 35
Member: 1564947 Status: Offline Thanks Meter: 13 | bro use hwk, select model b3313 , select files, insert battery ,press * then insert usb select com, press write flash , i tested many time ........................ if u like my post press thankx |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
