12-16-2009, 12:00 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: MX-KEY is the BEST NOKIA TOOL
Member: 965510 Status: Offline Thanks Meter: 8 | help regarding 1209.. 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84F8BE3D09D124142D84D12FD7 Decoded MSID: 3E4EBAE9-00B2C6A1-A8000000 Encoded FAID: D715F7B2-5D6372CF-31A99D17 IMAGE: rh105_05.910 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:27 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:13 IMAGE: rh1050_nai5.91el Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile flashed with latest version pls help |
12-16-2009, 13:12 | #5 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | bro. check carefully when u flash IMAGE: rh1050_nai5.91el show local mode for 2 second then cable problem if not show local mode then flash ic problem |
12-16-2009, 13:24 | #8 (permalink) |
Member: 669673 Status: Offline Thanks Meter: 301 | try this link ==== http://web3.lvps188-92-201-13.my-sim...e/index02.html |
12-16-2009, 13:42 | #10 (permalink) |
Member: 669673 Status: Offline Thanks Meter: 301 | try this with any version Red point will be not connected with cable i mean to say tape or streaker fix red point and try to flash i think yr will be problem solve otherwise 99.99% flash ic problem. |
The Following User Says Thank You to ravi mobile For This Useful Post: |
12-16-2009, 17:21 | #12 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | do nothing just press Erase button first of all after Erase flash your cell with any available firmware version sure 100% ok do ui settings Wr PM and do full factory defaults again |
help me 1209 contact service | haroum | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 03-10-2010 16:33 |
plz help me 1209 unlock | simomex | MT-BOX | 2 | 10-10-2009 22:29 |
Hi Cyclone Unlockers Plz Help In 1209 | chohansahib | Cyclonebox | 2 | 08-17-2009 23:26 |
Need help in 1209 | appu2009 | HWK | 23 | 03-27-2009 04:10 |
help regarding messed up OTE db | Dark Lemming | Alcatel & TCL Old Models | 3 | 01-21-2001 13:59 |
