01-22-2013, 23:02 | #7 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Neverland
Member: 1005489 Status: Offline Thanks Meter: 105 | Quote:
Connect hwk then select rm-618 X2-00 USB. Open interface and select USB. Click check button and insert usb cable,if not detect phone then reinsert battery and put usb cable into the phone. After phone is readed click 2 times on reset user lock(must do before phone restart). If want full UI settings just repeat operation,first check and before phone restart click 2 times on UI settings. Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-618] [2.2.0.3] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 000000000088011C3E31570801EEB96EB42B013F CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00200030-00000131, St OneNAND-1G CMT FLID1 : 00200030-00000131, St OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : E9700989029D9E899915F781B1582048E042A738 CMT ALG Boot OK PASUBTOC : PA_SL3 Rebooting Mobile Set Security Ok, Time: 00:23 Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-618] [2.2.0.3] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 000000000088011C3E31570801EEB96EB42B013F CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00200030-00000131, St OneNAND-1G CMT FLID1 : 00200030-00000131, St OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : E9700989029D9E899915F781B1582048E042A738 CMT ALG Boot OK PASUBTOC : PA_SL3 Rebooting Mobile Set UI Factory Defaults Ok, Time: 00:18 Last edited by satch1234; 01-22-2013 at 23:09. | |
The Following User Says Thank You to satch1234 For This Useful Post: |
01-23-2013, 13:51 | #9 (permalink) |
No Life Poster Join Date: Jul 2011 Location: india Age: 44
Member: 1623262 Status: Offline Sonork: 100.1621312 Thanks Meter: 96 | do ui setting otherwise just flash it ..... it takes only 10 seconds to flash........ |
The Following User Says Thank You to unuunu For This Useful Post: |
