12-27-2009, 12:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | how to flash LG KG 800 with HWK If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 98 00 4A [TOSHIBA] 08 BaudRate Set to: 921600 IMEI: 353223-02-012392-4 Read [01000000-01FFFFFF] Done, 04:07 Code Image Saved as KG800_CODE_.bif Read [04000000-04FFFFFF] Done, 04:05 Alchemy Image Saved as KG800_ALCH_.bif Aux Data, not Defined Region File: KG800P64-ARB-V10g-XXX-XX JUN 12 2006 702 AlchemyData.mot MOT Format File, Converting to BIF Region: 1, 0x04010000-0x04E81157, Length: 15143256 bytes Processed: 946454 record(s) Saved as KG800P64-ARB-V10g-XXX-XX JUN 12 2006 702 CodeData.bif Write [04010000-04E81157] Done, 04:06 Write [04010000-04E81157] Done, 04:06 Erase [04800000-04FFFFFF] Done, 00:36 File: KG800P64-ARB-V10g-XXX-XX JUN 12 2006 702 CodeData.mot MOT Format File, Converting to BIF Region: 1, 0x01000000-0x018D8CD7, Length: 9276632 bytes Processed: 579790 record(s) Saved as KG800P64-ARB-V10g-XXX-XX JUN 12 2006 702 CodeData.bif Write [01000000-01001FFF] Skipped Write [01002000-01003FFF] Skipped Write [01004000-01005FFF] Skipped Write [01006000-01007FFF] Skipped Write [01000000-018D8CD7] Done, 02:31 NOTE: when i download the file they were two files and flashing area there are three places to select the file |
12-27-2009, 13:45 | #2 (permalink) |
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | Anyone to help in this section plz i have flashed the set and it is dead now what file to select in number three file area |
12-27-2009, 16:53 | #3 (permalink) |
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | plz help MR. ODIA and Gsm Munna where are you!!!!!!!!!!!!!!!!!! i have download files but they are Alchemy and Code files there isn't AUX (Flex) file now the set is dead how to make it alive |
how to unlock lg kg 800 | ruvanw1979 | FuriousGold | 2 | 02-26-2009 07:51 |
Plz Help me how to flash Lg KG 270 | brain00000 | Infinity-Box | 2 | 06-05-2008 18:03 |
Plz Help me how to flash Lg KG 270 | brain00000 | Infinity-Box | 1 | 06-05-2008 12:09 |
how to flash lg 81xx by using hwk | markLEE | LG | 1 | 12-31-2005 10:21 |
