07-29-2008, 22:40 | #2 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | 1-you must have good Fbus cable (you can check the cable from software-connect the phone to cable and press check.) if have problem with flash algorithm just check -Dual line (if can). If your phone dirrect power on in normal mode your resistor have problem with BSI and your resistor from bsi must be correct change it with (5k or 7.5k to 10max). If your cable is not good and you can't see LOCAL or TEST MODE don't Downgrade. 2.Press info and you will see version of phone, after that download the version from support or other free server and instal it. from MCU section search for *.mcu* file. In PPM sector use *ppm* files (that is language pack and you can see all language from list) In Content pack (that is themes,image and other media files) you can choice any file from *image* format after that just press flash and see the log, if have problem with flashing post here and we will help you. If have other questions plese use SEARCH button or download the manuals from support. Before start all proces Please make PM backup (security area 308 adress) Press 308 backup and save it. Because if have any problem with flashing or other your phone will be killed or will have any other problem. Before all please make backups!!!!!! and aways flash with High versions because all bugs is fixed and if you flash the phone with old version the phone will be DEATH. If need from downgrade check DOWNGRADE and press after that. Best regards K k - chimeto. |
how to change the nokia software | jasim | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-13-2012 01:10 |
How to flash the life timer of nokia HPs to 0? | coldcar | Nokia Base Band 5 ( BB-5 ) | 2 | 02-20-2008 08:23 |
how to flash the new firmware to phone? | polychrome | Samsung Flashers, Software, Firmware. | 1 | 06-10-2007 22:35 |
TST, How to flash the I300? can we use the original USB Cable? | sim1 | TST Dongle | 5 | 01-21-2006 05:49 |
How to flash the gprs file to the phone using UFS? | hooi76 | UFS2 + UFS3-Tornadoflasher | 0 | 03-03-2005 02:35 |
