How To Flash Samsung E2652 How To Flash Samsung E2652 Phone Condition Only Show Download Mode I Try to UFS But Some Error First Phone Problem Sim Lock iI Try to Unlock on Z3X Box But Not Success or after This Condition http://img684.imageshack.us/img684/5289/e2652ufshwk.png How To Solve This Problem Pls Argent |
istall drivers at first, connect phone to usb without battery, and look to device manager |
if not works, can be usb loader damaged in phone, so use micro USB > RJ45 cable schematics can find on support |
already Install Driver , I Use Micro USB Cable But Same Problem |
Thanks For The Share Major-T I Try This Step Phone is Good Working But Sim lock Problem Note Solved |
How To Unlock Samsung E2652 on UFS HWK |
use original usb cable, select usb0 in baud rate, flash it with patch msl check box enabled read info after only patched firmware can read code, unlock or change imei after you succeed, can flash any what you want, phone remains unlocked |
helo sir i have sme problem in samsung e2652 Insert USB Cable to Switched Off Phone IF_USB: XGOLD213 IF_SBL: XGOLD213, Ok IFEBL_NO_RSP what to do |
E2652 successfully flashed Phone Condition Only Show Download Mode I Will try Z3X BUT not Ready... I Try to UFS But Very Good in HWK Insert USB Cable to Switched Off Phone IF_USB: XGOLD21x IF_SBL: XGOLD213, Ok IF_EBL: 6180_Bootloader_10.0_MKEYSKEY 10.0, Mode: BB FL_ID : EC000822, Samsung K8F5615ETM 256Mb Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:02 MSL Patched OK: 00:00 E2652XXKB2_BIN.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:15 Write Area: 0x40040000 - 0x41B1E766, Written: 00:54 E2652XXKB2_psi_flash.fls FLASH BUNDLE: Flash File: dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls Erase Area: 0x40000000 - 0x4003FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4002986A, Written: 00:00 E2652XXKB2_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x41F80000 - 0x41FFFFFE, Erased: 00:01 Write Area: 0x41F80000 - 0x41FE1A3A, Written: 00:01 E2652OXEKB2_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-E2652_OXE.dffs Erase Area: 0xA0C80000 - 0xA7A3FFFE, Erased: 00:00 Write Area: 0xA0C80000 - 0xA26F2ADE, Written: 01:06 E2652XXKB2_UI_IMAGE.fls FLASH BUNDLE: Flash File: temp_UI_IMAGE.fls Erase Area: 0xA0080000 - 0xA0C7FFFE, Erased: 00:00 Write Area: 0xA0080000 - 0xA07F30BE, Written: 00:14 ShutDown Done |
volume key up and lock key press cont ... with battry |
i need driver ......................... |
install kies and will have it |
Brother Check Here . http://forum.gsmhosting.com/vbb/f200...asher-1413209/ Br, One-Man ..::azimbahar::.. |
E2652 Sim lock Done by HWK Quote:
Right Solution Condition E2652 Sim lock Here is successful screen short http://i45.tinypic.com/2r40ark.jpg |
