Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 10-21-2011, 10:20   #1 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 110
How To Flash Samsung E2652
Phone Condition Only Show Download Mode
I Try to UFS But Some Error
First Phone Problem Sim Lock iI Try to Unlock on Z3X Box But Not Success or after This Condition
How To Solve This Problem Pls Argent
Old 10-21-2011, 10:36   #2 (permalink)
Member: 904530
Thanks Meter: 513
istall drivers at first, connect phone to usb without battery,
and look to device manager
The Following User Says Thank You to Major-T For This Useful Post:
Old 10-21-2011, 10:38   #3 (permalink)
Member: 904530
Thanks Meter: 513
if not works, can be usb loader damaged in phone,
so use micro USB > RJ45 cable
schematics can find on support
Old 10-21-2011, 10:51   #4 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 110
already Install Driver , I Use Micro USB Cable But Same Problem
Old 10-21-2011, 11:06   #5 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 110
Thanks For The Share Major-T
I Try This Step Phone is Good Working But Sim lock Problem Note Solved
Old 10-21-2011, 11:07   #6 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 110
How To Unlock Samsung E2652 on UFS HWK
Old 10-21-2011, 12:07   #7 (permalink)
Member: 904530
Thanks Meter: 513
use original usb cable, select usb0 in baud rate,
flash it with patch msl check box enabled
read info after
only patched firmware can read code, unlock or change imei
after you succeed, can flash any what you want,
phone remains unlocked
Old 11-13-2011, 16:23   #8 (permalink)
Crazy Poster
Member: 556520
Thanks Meter: 3
helo sir i have sme problem in samsung e2652
Insert USB Cable to Switched Off Phone
IF_USB: XGOLD213
IF_SBL: XGOLD213, Ok
IFEBL_NO_RSP
what to do
Old 11-17-2011, 07:49   #9 (permalink)
santhusystems's Avatar
Member: 1170625
Sonork: 100.1616527
Thanks Meter: 94
E2652 successfully flashed
I Will try Z3X BUT not Ready...
I Try to UFS But Very Good in HWK
IF_USB: XGOLD21x
IF_EBL: 6180_Bootloader_10.0_MKEYSKEY 10.0, Mode: BB
FL_ID : EC000822, Samsung K8F5615ETM 256Mb
Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:02
MSL Patched OK: 00:00
E2652XXKB2_BIN.fls FLASH BUNDLE:
Flash File: CATFISH.fls
Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:15
Write Area: 0x40040000 - 0x41B1E766, Written: 00:54
E2652XXKB2_psi_flash.fls FLASH BUNDLE:
Flash File: dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls
Erase Area: 0x40000000 - 0x4003FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4002986A, Written: 00:00
E2652XXKB2_CDS.fls FLASH BUNDLE:
Erase Area: 0x41F80000 - 0x41FFFFFE, Erased: 00:01
Write Area: 0x41F80000 - 0x41FE1A3A, Written: 00:01
E2652OXEKB2_CSC.dffs FLASH BUNDLE:
Flash File: temp_GT-E2652_OXE.dffs
Erase Area: 0xA0C80000 - 0xA7A3FFFE, Erased: 00:00
Write Area: 0xA0C80000 - 0xA26F2ADE, Written: 01:06
E2652XXKB2_UI_IMAGE.fls FLASH BUNDLE:
Flash File: temp_UI_IMAGE.fls
Erase Area: 0xA0080000 - 0xA0C7FFFE, Erased: 00:00
Write Area: 0xA0080000 - 0xA07F30BE, Written: 00:14
ShutDown Done
Old 12-05-2011, 14:51   #10 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 108
volume key up and lock key press cont ... with battry
The Following User Says Thank You to gokul2005 For This Useful Post:
Old 01-12-2012, 05:06   #11 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,580
i need driver .........................
Old 01-12-2012, 05:12   #12 (permalink)
Member: 904530
Thanks Meter: 513
install kies and will have it
Old 01-12-2012, 13:10   #13 (permalink)
Member: 1174508
Sonork: 100.1593820
problem solved . no need kies
here more
Samsung e2652 successfully flash done with flasher .
Old 07-28-2012, 11:27   #14 (permalink)
Member: 1174508
Sonork: 100.1593820
Originally Posted by kk14150 View Post
i i flash e2652 ufs but err ppllllszzzzzzzzz help meeee urgent
Brother Check Here .
Br,
One-Man
..::azimbahar::..
Old 08-25-2012, 12:06   #15 (permalink)
Member: 866650
Sonork: mdsalimkhan_05
Thanks Meter: 134
E2652 Sim lock Done by HWK
read info after
Right Solution
Condition E2652 Sim lock
Here is successful screen short
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.47375 seconds with 8 queries
