09-04-2008, 17:01 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: karachi pakistan Age: 35
Member: 476667 Status: Offline Thanks Meter: 56 | how to modify ? any diagram or schematic will be appreciated thanks in advance. |
09-04-2008, 18:36 | #3 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | here is ur solution.... http:///vbb/showthread.php?t=313161 |
09-05-2008, 00:04 | #4 (permalink) |
Freak Poster Join Date: Jan 2004 Location: netherlands Age: 42
Member: 50272 Status: Offline Thanks Meter: 37 | no need chang for all models. new bb5 need 7 pin-dual lines cables. must new cable on market already 7pins just you need is select DUAL LINE into hwk sw. for pinouts use seach button there is 100 time posted how to 5 pin to 7 pin for use Dual line. ( dont-never connect 9v to 7 pin dual line using cables ) |
The Following User Says Thank You to Secgsm For This Useful Post: |
How to modify 7610 ringer to louder | kelvinlim | Nokia Hardware & Hardware Repair | 3 | 05-18-2007 15:46 |
how to modify vygis KG800 cable to work with ufs | btyazoo | HWK | 1 | 07-29-2006 20:08 |
how to modify the flash file to unprotect it?? | Kevin perez | Mitsubishi | 5 | 10-06-2003 11:49 |
How to modify GD90 cable to GD87 cable for unlock? | rango | Panasonic | 4 | 07-02-2003 09:17 |
How to modify my cable to unlock A300 with All Samsung 3.0 | balivo | VLSI, Conexant, Skyworks and Old Models | 9 | 05-27-2002 13:28 |
