How to remove samsung c3322 lock code? Any way to remove this phone asking lock code? |
no one done this phone before? |
SAMs v2.2.0.2 -------------- TRIDENT VISION <CODE CORRUPTED> for non 8 Digits PCK Fixed. SWIFT-AEROFONE E1050-CHN,E1050V,E1086i,E1150-CHN,E1155L,E1180,E1190,E1220i added (PUNL,PIM,FL) E1182L added (DUNL,PUNL,PIM,FL) E1225T,E1182 TFS Flashing bug Fixed. C3322 Unlock, IMEI, Sections bug Fixed. B7722,B7732 Slave Part Flashing/Read/E2P added. QUALCOMM T669 Added. INFINEON C3011,C3560,C3750,C3752 added (CUNL,PUNL,PIM,FL,UFL) E2232 Flashing bug Fixed. <CODE CORRUPTED> for non 8 Digits PCK Fixed. unlock supported |
Connect your phone to ufs and press unlock without battery. |
Which cable to use? Usb micro or uart micro ,how to connect cable? |
micro usb - rj45 cable with 523k resistor on id pin same as for c3303 |
I believe your phone is asking for phone lock code with inserting sim into your phone. If so, you need Micro Uart Usb Cable to connect your phone to the pc and of course you would have had samsung pc studio or relevant samsung drivers installed into your pc to drive the phone as soon as you connect it. After phone is recognized by pc just press INFO on hwk samsung software and there you have your phone unlock code. |
[email protected] |
1.choose the model in z3x 2.in option tab change to flashmode from tatmode 3.press unlock u will get this msg voldown +lock button instead of this press 1+3 insert micro usb cable it il detect tick use usb cable must |
thanks pree 1+3 and insert usb cable phone will be unlock in sec try |
here is also usercode reset through HWK,simply with rj45 cable/unlock=user code reset. tell me also how i can post a new solution if found any?i didnt find any link on forum from where i ll post that. |
how to unfreeze samsung GT-s5600? what i have to do? IMEI :358555/03/249447/9 help please..thanx |
