How to unlock samsung b3210 ? Mates, here i got a phone locked 3210 it got connected to usb cable as com port 8 to PC any 1 who is experienced with this model be please to share your idea to unlock this phone with hwk thanks advanced. NEIL |
Phone Must be with Battery and Powered On ! MSL : Active S/N : RVUSC79097 To Make MSL Bypass in USB Mode, Use [Read Codes] at first ! Network Keys Reset Failed I shall report after trying the method in support regards, NEIL |
Solution already avaliable on Support Area. Root / HWK_SW/ How to Unlock USB only phones [B3210,B3310].txt Hope you resolve your problem.!! Munna. |
yes done it simply followed the text 100% OK thanks HWK team regards, NEIL |
i have the procedure with usb cable from support but i can't enter phone in usb download mode. phone only power on after press Hold * button power and insert cable read info give this: Quote:
do this 1. Switch On Phone and Connect USB Cable. 2. Select ssm1 port in [Interface] ComboBox. 3. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 To Make MSL Bypass in USB Mode, Use [Repair MSL] at first ! (not need to Write E2P or MCU ) Locks: Error 4. Disconnect USB cable, Switch Off Phone. 5. Enter Phone to USB Download Mode (Hold * button and insert Cable) 6. Select ssm0 port in [Interface] ComboBox. 7. Press [Repair MSL] button, software will ask about S/N, make sure is same as see in Info. Not need write any MCU or E2P files. Using MSL S/N: RD3SC79975 USB Boot Ok, McuId: 00050015, Ubl: BC8906B3, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:01, 0 Flashing NOR part... Write Done, 262160 byte(s), Time: 00:01 8. Disconnect USB cable, Switch On Phone. 9. Select ssm1 port in [Interface] ComboBox. 10. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 MSL : Deactivated PCK : 00000000 [#0141*00000000#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 15234981 [#0111*15234981#] 11. Now can use Unlock Codes or do any other Operations (Repair IMEI, etc.) Phone not need anymore to [Repair MSL] |
i already unlock the phone follow the procedure you got from support area. my problem was to put mode in download mode! now it is ok and phone unlock |
I cant unlock b3210 Phone Must be with Battery and Powered On ! Failed to enter Test Mode |
failed to enter test mode. n.b. i have followed the instructions in support. when in download mode i can do all the operation including read and write. what might be the issue,tried with three diff handsets same issue. can it be improper installation of drivers? in DEVICE MANAGER under ports it reads as SAMSUNG MOBILE USB PORT,and under USB CONTROLLERS it reads as samsung mobile usb device. |
nice job alifahd thanxs..tested by me 100% |
Done Thanks GSM muna i got txt file here i mention all method 1. Switch On Phone and Connect USB Cable. 2. Select ssm1 port in [Interface] ComboBox. 3. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 To Make MSL Bypass in USB Mode, Use [Repair MSL] at first ! (not need to Write E2P or MCU ) Locks: Error 4. Disconnect USB cable, Switch Off Phone. 5. Enter Phone to USB Download Mode (Hold * button and insert Cable) 6. Select ssm0 port in [Interface] ComboBox. 7. Press [Repair MSL] button, software will ask about S/N, make sure is same as see in Info. Not need write any MCU or E2P files. Using MSL S/N: RD3SC79975 USB Boot Ok, McuId: 00050015, Ubl: BC8906B3, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:01, 0 Flashing NOR part... Write Done, 262160 byte(s), Time: 00:01 8. Disconnect USB cable, Switch On Phone. 9. Select ssm1 port in [Interface] ComboBox. 10. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 MSL : Deactivated PCK : 00000000 [#0141*00000000#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 15234981 [#0111*15234981#] 11. Now can use Unlock Codes or do any other Operations (Repair IMEI, etc.) Phone not need anymore to [Repair MSL] |
Thanks, Nice job. tested and working 100%. remember to insert wrong simcard before entering the codes. Just whatever is NOT 00000000 one by one till it unlocks |
Samsung b3210 unlock done with z3x SAMSUNG B3210 UNLOCK DONE WITH Z3X JUS CONECT USB CABLE PRESS INFO... BUTTON Selected model: B3210 Selected com port: COM43 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: B3210JVIJ3 Langpack: Algeria, Egypt, Iran, Iraq, Kuwait, Morocco, Nigeria, Oman, Pakistan, Saudi Arabia, South Africa, Syria, Tunisia, Turkey IMEI: 35 S/N: RVSSC27447 HW-> MP 0.600 Phone password: 1602 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 88b00000 Flash size: 134217728 Bytes Flash sectors: 512 sectors Bluetooth ID: 44f459-ae9eb4 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Calculated code please wait Decrypted time: 105 sec [NCK]:#0111*00000000# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*18221834# Read info - ok Elapsed time: 134 second, sw ver: 3.5.0025 BR, AM_GSM_CELL...:::AWAIS.AS:::... |
Success fully Unlocked Samsung B3210 with UFS HWK Success fully Unlocked Samsung B3210 with UFS HWK Thanks Team Good Trick ... Software: B3210DDJA1 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2010 January Rev: 1 CSC Vers: B3210ODDJA1 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2010 January Rev: 1 Hardware: MP 0.601 IMEI: 359007-03-299299-7 BT Address: d4e8b2-fa4021 User Lock : 00000000 Lock Level: 00 [Not Locked] MSL : Active S/N : RW4Z995963 MSL : Deactivated PCK : 992318 [#0141*992318#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 77548554 [#0199*77548554#] Big Thanks For UFS HWK Team ....! |
100% agree with u this method is tested .. u must repair msl to unlock that cellphone |
