Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 01-21-2008, 12:41   #1 (permalink)
Member: 199842
Thanks Meter: 3
HWK 2.0.6.0 Not Auth problem
Hi there, ive been on the forum for a bit but lost my older account but anyway.. i keep getting an error with 2.0.6.0 .. Its updated the hwk fine runs for a few days no problems then comes up with an error
None Authorised Copy of software detected please use original install package.. but the thing is i grabbed it from the support section via the button in hwk.. running a repair with the hwk suite file fixes the error until it happens again.. Any light people can shine on it?
Cheers
Icumobile
Old 01-21-2008, 13:55   #2 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Cheers
Icumobile
It sounds like you have some PC Cleaning utility which is deleting the UFS+HWK registry keys.
Odia.
Old 01-21-2008, 16:21   #3 (permalink)
kiricu's Avatar
Member: 206710
Thanks Meter: 13
Hi Odia,
I have same problem with my laptop but only if I insert USB portable HD.
Have you an answer for this behaviour?
thank you and Best Regards
kiricu
Old 01-21-2008, 22:15   #4 (permalink)
Member: 4042
Yes it should not happen, we are looking into this issue, I found this just after release, once the portable HD is removed all will be ok.
If you need to use the suite when portable is connected, you need to run HWK Suite Setup until after initial procgess bar and then quit, but you will need to do this again after its removed
Odia.
Old 01-22-2008, 19:59   #5 (permalink)
kiricu's Avatar
Member: 206710
Thanks Meter: 13
Hi Odia,
thanks for your answer, but i prefer to wait for next update with bug fixed...
kiricu
Old 03-09-2008, 14:48   #6 (permalink)
Member: 259909
Thanks Meter: 4
hi plz help me my ufs is all good .its unlocking all models but when i go to flash to any phone it says hwk error.plz help
i try with all new and old versions
Old 03-09-2008, 19:06   #7 (permalink)
telemoveis's Avatar
Member: 83577
Thanks Meter: 11
problem updater
Wait, Trying to Repair HWK ...
FAILED to ENTER FLASHER: 54C454
HWK 2.0.6.0 , 7 Pin cable - How to init local mode ? FreeMaind_next HWK 14 05-27-2008 15:37
HWK 2.0.6.0 not authorised problem Icumobile HWK 3 01-21-2008 17:16
ufs3 hwk v2.0.6.0 problem giftb31 HWK 7 11-26-2007 05:30
There is no unlocking support for Nokia 2660 in new hwk 2.0.6.0 milkyctg HWK 0 11-12-2007 00:57
Page generated in 0.16136 seconds with 9 queries
