08-19-2009, 05:19 | #1 (permalink) |
Crazy Poster Join Date: Apr 2008 Location: C:/Windows/System32/
Member: 744020 Status: Offline Thanks Meter: 14 | hwk 2.0.9 update error plz help me Upgrade log: ---------- HWK Update Client v 2.0.8.0 ---------- ---------- HWK upgrade started:8/19/2009 12:34:08 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : jhay_0926 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-BBF6jhay_0926008 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
08-19-2009, 05:28 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: United Harvard Paris Age: 33
Member: 492345 Status: Offline Sonork: 100.1594007 Thanks Meter: 161 | maybe this will Help you brother... http://forum.gsmhosting.com/vbb/showthread.php?t=808744 Code: Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite. You MUST update your HWK using client 2.0.9.0, old client versions will no longer work. You MUST be running HWK software 2.0.9.0 to access support. |
The Following 3 Users Say Thank You to Euan For This Useful Post: |
08-19-2009, 05:44 | #5 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
this is the problem | |
08-19-2009, 07:38 | #6 (permalink) |
Freak Poster Join Date: May 2004 Location: algeria
Member: 64587 Status: Offline Thanks Meter: 39 | uninstal the previous package then install the support suite the upgrade with the new update client 2.0.9 |
The Following User Says Thank You to salim_belka2002 For This Useful Post: |
08-19-2009, 09:37 | #7 (permalink) | |
Junior Member Join Date: Aug 2008 Location: bangalore
Member: 827590 Status: Offline Thanks Meter: 5 | i have downloaded hwk support suite , but is not updating.below message is showing Quote:
i have downloaded hwk support suite , but is not updating.below message is showing | |
