Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 01-23-2009, 03:59   #1 (permalink)
Member: 921088
Thanks Meter: 46
HWK 2.08 cant use on other PC
HWK 2.08 cant use on other PC...need help
Old 01-23-2009, 04:23   #2 (permalink)
Member: 904530
Thanks Meter: 512
which reg edit ? run suite again and press cancel.
and do this for every new box connected to pc which
says "none authorised..."
Old 01-23-2009, 05:23   #3 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
HWK 2ND pc Solution For Set Up 2.08
1. uninstall ur old hwk suite from control panel of ur pc.
2. uninstall ur old hwk support Suite from control panel of ur pc.
Ununst all Drivers also.
2a. Run emergency cleanup.reg and restart PC
3. Install new HWK_Support_Suite_Setup_v02.08.000.exe
4. Than connect ur box , Install Driver, and start UpdateClient.exe, just wait for a minute untill it recognise Sr. No , Licence etc.
5. Donot need to Start HWK Update AS it has been already Updated .
6. Just quit HWK update Client V 2.0.8.0
7. Run hwk 2.0.8.reg , Then Run Global option.reg.
8. Now install HWK_Setup_Suite_v02.08.000.exe
9. Now Start DCTx BB5 and connect Box, if Unaithorised Error occur then
run again Setup 208 and click on repair.
Find Reg Cleaner, REg 208 and gobal option posted already in forum.
100 % Tested on 3 PCs this week only.
Regards.
The Following User Says Thank You to rajumobile For This Useful Post:
Old 01-23-2009, 05:42   #4 (permalink)
Member: 904530
Thanks Meter: 512
what you are here writing ? why need edit registry ?
just install suite, not need upgrade box if is already upgraded.
run Sams or BB5, will see : 'None authorised copy of software ...'
after run suite again (big one or 2081) and press cancel, when have message what is already installed.
Old 01-24-2009, 06:00   #5 (permalink)
Member: 954572
could u give me "Find Reg Cleaner, REg 208 and gobal option or emergency cleanup.reg "
Old 01-24-2009, 06:07   #6 (permalink)
-=whitezaNder=-'s Avatar
Member: 484671
Thanks Meter: 80
or update it again then re-install to which pc you use
Old 01-24-2009, 06:12   #7 (permalink)
Member: 954572
boss,how can i have software cleanup old hwk driver,could u help me plz...
Old 01-24-2009, 09:52   #8 (permalink)
flasdaft's Avatar
Member: 282308
Thanks Meter: 44
Type regedit on pc that hwk is installed on,then HKEY_LOCAL_MACHINE then click the plus sign on SOFTWARE & go down to SarasSoft,right click the sarasSoft & save reg key,put it on flashpen or mem card and double click it on 2nd machine,install HWK suite & it will work 1000% mate
Regards
Page generated in 0.28049 seconds with 8 queries
