08-30-2008, 16:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 231650 Status: Offline Thanks Meter: 51 | hwk installation problem |
08-31-2008, 07:45 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Press Start -> Run -> type "regedit" enter HKEY_LOCAL_MACHINE -> SOFTWARE -> SarasSoft -> UFS3 (highlight GlobalOptions) change the value of client runtime from 0 to 1. | |
08-31-2008, 10:34 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Again try this- 1.If you have Windows XP Professional and access to an administrative user account, you could change the registry editor options in the Group Policy Editor. Click Start, Run Type GPEDIT.MSC and Press Enter Go to the following location User Configuration Administrative Templates System In the Settings Window, find the option for "Prevent Access to Registry Editing Tools" and double-click on it to change. Select Disabled or Not Configured and choose OK Close the Group Policy Editor and restart your computer Try opening REGEDIT again Note:- this option also doesn't works if you have any virus or trojan in your PC. 2. Use this software Usage: Download regtools.vbs Save the file to the folder of your choice. Double click the VBS file. The VB Script file will check for the appropriate value and if not found will create it. If the value was found, it will be toggled to its opposite state and you will be informed that you need to log off/back on or restart your computer. One note. This change is made in HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System. Disabling the tools takes effect immediately. Enabling requires a restart. This script can be viewed in Notepad or any text editor, as to the specific Registry key and value that are updated. Your antivirus software may report this script as potentially malicious, or a possible virus. This is because the script writes to the System Registry. Last edited by PASSIONATE_BOYS; 08-31-2008 at 10:37. Reason: Added 2nd Option |
HWK install problem after format PC. | rajumobile | HWK | 3 | 11-08-2008 08:06 |
new hwk install problem | urromeo | UFS2 + UFS3-Tornadoflasher | 2 | 07-30-2008 08:32 |
hwk installation Problem Please help | gsmhosting | HWK | 1 | 05-11-2008 15:25 |
help hwk Installation problem | visionmaster20 | HWK | 2 | 04-18-2008 19:32 |
