01-26-2013, 15:23 | #20 (permalink) | |
Major Poster Join Date: Jan 2013
Member: 1871879 Status: Offline Thanks Meter: 2 | Quote: Can someone tell me where to find instructions? | |
01-26-2013, 16:28 | #25 (permalink) |
Member: 1871879 Status: Offline Thanks Meter: 2 | I've tried all of these with 10357319 as the unlock: Code: Model : Most Nokia's (excluding BB5 Models) 1 - Switch ON your Nokia phone without a SIM Card 2 - Enter the +7 code ( e.g. #PW+XXXXXXXXXXXXXXX+7# ) Important Note: If your model is a Nokia BB5 Model then you need to enter #PW+XXXXXXXXXXXXXXX+1# The letter P will appear after quickly pressing the star button ( * ) 3 times The letter W will appear after quickly pressing the star button ( * ) 4 times The letter + will appear after quickly pressing the star button ( * ) 2 times 3 - The phone should show the message "SIM Restriction Off" or a similar message to confirm that is it unlocked! 4 - You will not need to enter any of the other codes but it will not harm your Nokia phone if you choose to enter all the codes. If nothing happens after you enter the full unlocking code, re-enter the code using these alternative method. Alternative method 1: Most Nokia Phone Models 1 - Switch ON your Nokia phone with a sim card that it does NOT accept 2 - The Nokia phone will either prompt you for a restriction code or give you the option to click on "undo" 3 - Now re-enter the unlock code and you should get the message "SIM Restriction Off" or a similar message. 4 - You will not need to enter any of the other codes but it will not harm your Nokia phone if you choose to enter all the codes. Alternative method 2: Newer Nokia Models 1 - Switch ON your Nokia phone with a sim card that it accepts and allow the phone to load to the main screen 2 - Now type the unlock code and press the green call button to enter it (you may not need to hit the green button) 3 - You should get the message "SIM Restriction Off" or a similar message to confirm that the phone is now unlocked. 4 - You will not need to enter any of the other codes but it will not harm your phone if you choose to enter all the codes. 5 - If the #PW+XXXXXXXXXXXXXXX+7# does not work try the PW+XXXXXXXXXXXXXXX+1# |
03-05-2013, 22:58 | #29 (permalink) |
Freak Poster Join Date: Feb 2011 Location: ALGERIA Age: 43
Member: 1513870 Status: Offline Thanks Meter: 46 | 2047 may be in 2047 and in 2047 you will ask about nokia rz800 new model and answer you by wait or firmware not supported or bf in in generally you must be waiting cus no box suported sl3 and dct4 new brand i said this in 2013 |
