Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 05-14-2007, 23:52   #16 (permalink)
Odia The Ultimate's Avatar
Member: 4042
HWK Release 14/05/2007
Release Date: 14/05/2007
The Official release will be ready in our download area
www.ufsxhwk.com.
You can download from here, until the support site can be updated:-
http://rapidshare.com/files/31347231/HWK_Suite_v02.05.002.exe.html
WARNING !!!
If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
NOTE: IF YOU HAVE UPGRADED YOUR UFS + HWK SUCESSFUL WITH SUITE V3.0.4 - V3.0.4.2, THERE IS NO NEED TO USE THE CLIENT AGAIN IN THIS VERSION
DCTxBB5 v2.0.5.2
1. Added BB5 files integrity check, while flashing.
2. Fixed some minor bugs in "Init SimLocks".
3. Added Dejan solution for BB5 ("Locks") 6630,6680,6681,n70,n90 etc... Test others on your OWN risk!
Many thanks to all those who have supported us!!!
Special thanks to Dejan for releasing the solution, respect from SarasSoft!!!
Odia.
www.sarasbox.co.uk
www.gsm-solutions.co.uk
The Following 16 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 05-23-2007, 11:38   #17 (permalink)
Member: 4042
Thumbs up HWK Release 23/05/2007
Release Date: 23/05/2007
The Official release is in our download area
www.ufsxhwk.com.
WARNING !!!
DCTxBB5 v2.0.5.3
1. Modified BB5 codes enter, to allow unlock "Counter Expired".
Odia.
www.sarasbox.co.uk
The Following 14 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 05-29-2007, 13:35   #18 (permalink)
Member: 4042
Thumbs up HWK Release 29/05/2007
Release Date: 29/05/2007
www.ufsxhwk.com.
http://rapidshare.com/files/34039781/HWK_Suite_v02.05.004.exe.html
WARNING !!!
SAMs V 2.0.5.4
TRIDENT
U600,U608 added.
"Test Mode" enter improved.
Warning about Battery usage, during UI operations.
Corrected Reserved Regions for some models(D83x,D84x,E90x,P31x,X82x)
Added MSL calculation, allows direct unlock and show correct
codes for new models(D83x,E570,E90x,P31x,U60x,X5xx,X63x,X68x,X8x x,.)
IMEI challenger implemented, allows rebuild IMEI for new models.
Odia.
www.sarasbox.co.uk
The Following 15 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 08-04-2007, 14:08   #19 (permalink)
Member: 4042
Thumbs up HWK Release 04/08/2007
Release Date: 04/08/2007
www.ufsxhwk.com.
http://rapidshare.com/files/46916210...5.005.exe.html
WARNING !!!
LG_GSM V 2.0.5.5
1. Fixed support of Spansion MirrorBit Flash chips.
2. Infineon SuperGold2 models added (KE850,KE970, ...)
3. Infineon EgoldVoice models added (KG270,KG271,...)
Warning Infineon models works with battery only !
4. Mediatek models added (C2500, C2600, ...)
SAMs V 2.0.5.5
TRIDENT
E840,F300,F308,U100,U108 added.
Full Reset(*2767*3855#)is mandatory after flashing !
If make Asia<>EU change, use *2767*3855# before flashing.
SWIFT
D900i,D908i,E200,E208,E390,E398,E590,E740,E830,E83 8 added.
Odia.
www.sarasbox.co.uk
Old 08-18-2007, 15:27   #20 (permalink)
Member: 4042
Thumbs up HWK Release 18/08/2007
Release Date: 18/08/2007
www.ufsxhwk.com.
http://rapidshare.com/files/49761459...5.006.exe.html
WARNING !!!
New Support Area Access - All you need is an Original HWK who's HID is in the master database (can be updated with update client), no username, no password, no waiting for activation. - We hope you will all enjoy this small gift and it will make ours and our customers lifes easier
LG_GSM V 2.0.5.6
1. API Updated to allow support access (No user update)
SAMs V 2.0.5.6
SeDBx V 1.0.5.6
1. Initial Public Release - This module will be updated over the next few weeks to become inline with the rest of the HWK Suite of Modules.
(See sticky post - SeDBx Quick Guide for information on how to use this new module)
Odia.
www.sarasbox.co.uk
The Following 17 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 09-13-2007, 08:58   #21 (permalink)
Member: 4042
Thumbs up HWK Release 13/09/2007
Release Date: 13/09/2007
http://rapidshare.com/files/55317801...5.007.exe.html
This release contains a new update client which resolves the cannot open URL message, some users have had over the last few days.
WARNING !!!
LG_GSM V 2.0.5.7
1. Infineon SuperGold2 models unlock (KE850,KE970, ...)
2. KE970GO added (KE970G)
SAMs V 2.0.5.7
TRIDENT
C520,M300,M600,X526 added.
SeDBx V 1.0.5.7
1. DB2020 User Lock code reset to 0000.
2. GDFS Info (Displays User Lock code for non DB2020 models)
Odia.
www.sarasbox.co.uk
The Following 18 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 10-28-2007, 09:51   #22 (permalink)
Member: 4042
Thumbs up HWK Release 28/10/2007
Release Date: 28/10/2007
The Official release is ready in our download area http://sarunasoftware.com/cardmain.php?dir=HWK_SW/.
Please run the upgrade client after you have installed the software, follow the instructions careful.
The Update Client is launched after install, if you cancel without making the update, you can run the Update Client again, by selecting the shortcut on the Start Menu:-
Programs\SarasSoft\UFS\Utilities\Update Client
WARNING !!!
New Users or users who un-installed the old version, should download and install the HWK Support Suite and run the client, before trying to install the full HWK Suite
UFS_DCTxBB5 v2.0.6
1. Dual Line flashing for BB5 introduced (Required UFS firmware V2.8 2007)
2. All avalaible phones supported (including RAPIDO v1.12, v1.13)
3. "Verify" function for BB5 added.
4. Latest Flash Update pack (7.40.35.29728) supported.
5. Support of Muxed Nand.
Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. This has always been the case with 7 pin cables, but from this release 7 pin cables are supported by UFS+HWK.
UFS_LG_GSM v2.0.6
1. KG290 support added.
2. "Support" button, to access support site.
UFS_SAMs v2.0.6
COMMON
Remade user interface.
TRIDENT
E950,F200,J600,J600E,J608,U300,U308,X830N added.
Read Codes for J600,J600E,J608
SWIFT
E598,E768,G600 added.
Unlock Codes on Info for D820,D900,E250,E740,G600.
UFS_SeDBx v2.0.6
1. "Skip Info Checking" allows reflash dead phones.
Odia.
www.sarasbox.co.uk
Old 03-20-2008, 22:13   #23 (permalink)
Member: 4042
Thumbs up HWK Release 21/03/2008
Release Date: 21/03/2008
The Official release is ready in our download area http://sarunasoftware.com.
Please follow the instructions careful on the above page.
The Update Client is launched after HWK Support Suite install, if you cancel without making the update, you can run the Update Client again, by selecting the shortcut on the Start Menu:-
WARNING !!!
NOTE: Support Access is via the software modules only, download managers have been limited to 3 connections.
UFS_DCTxBB5 v2.0.7
1. New BB5 products:
RM-179,RM-223,RM-233,RM-244,RM-256,RM-264,RM-269,RM-278,RM-279,
RM-313,RM-314,RM-320,RM-321,RM-322,RM-323,RM-397,RM-421,RM-426
(N81-1,N81-3,8800e-1,E51-1,N81-5,7900d-1,N81-6,6500s-5,5610d-5,N82-1,
N82-2,N95-2 8G,N95-6 8G,6301,6301b,6500c-5,N95-4,E51-2)
2. ISM flashing support for BB5 products.
3. Improved DCT4/WD2 Flash Loaders version display.
4. Fixed BB5 PM file open bug.
5. Improved Extended PHONET messages handling.
6. Store of Ext.VPP setting in INI file.
7. Support of new Flash Chips.
8. Fixed CNT flashing for 7370 and 6151.
9. Flash Update pack (7.46.43.30662) added.
UFS_LG_GSM v2.0.7
1. KG280, KP200, KP202, MG280 support added.
UFS_SAMs v2.0.7
TRIDENT
C170,C178,C188,E210,E218,E840B,E848,E870,E878,E888 ,E958,
F210,F218,P520(******),M608,T519,T629,U600B,U608B added.
OM(SYSOL)
C160,C160B,C160L,C160M,C166,C168,C180,C450,C458,CC 03,
M110,X540,X550 added.
E2P unlock fixed for E420,E428...
Implemented MSL calculation, allows direct unlock
without E2P corruption and shows correct codes.
Rebuild of corrupted Master Key during wrong unlock.
IMEI rebuild for new models (Sysol3)
SWIFT
D880,D888(Duos),E746,G608,L600,L608,M610,M618 added.
Implemented MSL calculation, allows direct unlock, and
show correct codes, without any data lose or setting to
default values of MSL, BTID, IMEI or Radio settings.
E2P Sections Read/Write introduced (compatible with TAT)
IMEI and BTID rebuild.(Imei option for Swift_1 only now)
Fixed bug of 0 length TFS files flashing (affected:
java appletts in D880, E200, E250, G600, M610 products)
COMMON INFO
E2P(hee)sections R/W allows to transfer calibration data,
radio setttings, etc. from product to product, without
damage to other vital data, unlike E2P or FULL clone.
Or allows to Read-Edit-Write well known values.
Warning,
Access to some sections can be denied by firmware, or
can have different values dependand on firmware version.
In case of protected or none existing section will have
result length of 0 or lose of TAT mode.
Odia.
www.sarasbox.co.uk
Old 05-14-2008, 06:31   #24 (permalink)
Member: 4042
Thumbs up HWK Release 14/05/2008
Release Date: 14/05/2008
Since this is a MINOR release there is NO need to update your HWK, there is also NO need to remove HWK Suite v2.0.7
WARNING !!!
UFS_DCTxBB5 v2.0.7.1
1. New BB5 products: RM-337,RM-364,RM-365,RM-366,RM-451
(6300i,3120c-x,8800e-5)
2. New DCT4 products: RM-340,RM-341,RM-362,RM-363
(2600c-2,2600c-2b,5000d-2,5000d-2b)
3. Flash Update pack (8.6.1.31560) added.
4. New RAP, UPP ASIC's and FLASH Chip's support.
5. New DCT4+ product unlock (see corresponding list)
6. BB5 ASK file will be created during "Rd Cert"
Odia.
www.sarasbox.co.uk
Old 05-23-2008, 17:32   #25 (permalink)
Member: 4042
Thumbs up HWK Release 23/05/2008
Release Date: 23/05/2008
Since this is a MINOR release there is NO need to update your HWK, there is also NO need to remove HWK Suite v2.0.7.x
WARNING !!!
UFS_DCTxBB5 v2.0.7.2
1. New DCT4+ versions support:
1200b(RH-100 v5.06)2600c(RM-340 v561)
SAMs V 2.0.7.2
TRIDENT
B100,B108,B200,B300,S710i added (DUNL,IM,FL)
B100,U600,U600B MSL Repair introduced.
OM(SYSOL)
C420,C420L,C421,C425,C426,X560,X560L,X566
added (DUNL,IM,FL,SECT)
SWIFT
E747.F250,F258,J700 added (DUNL,FL,SECT)
Chinese FOTA products E838, J708 flashing.
Added sectors count for RAW NAND read.
COMMON INFO
Product filter added.
SeDBx v2.0.7.2
1. USB Flashing introduced.
2. CID53 Support for DB2020 and PNX5230 platforms.
3. CID Upgrade introduced.
4. FS Upgrade files flashing. (FSUPG)
5. GDFS Info now Displays User Lock code for DB2012 models also.
USB Drivers are installed to X:\Program Files\SarasSoft\UFS\UFS_DBX\USBFlashDriver
SeDBx Quick Guide has been updated.
Odia.
www.sarasbox.co.uk
The Following 158 Users Say Thank You to Odia The Ultimate For This Useful Post:
***MADHUR***, *PROPHONE*, ..::: Naveed :::.., ..::AppleLinks::.., ..::M-GSM::.., .:Mahmoud El-masy:., .:Shorbagy Team:., 2net2, ab1009, abdulrahimkhan, ahmedzameer, ajazsha, alamgir80, aleon, alfergany, aliahmedshaik, alz0nta7y, amko, amr_ibrahim, arfono, artech2, asrar, azo1yvo1, badism16, balLlroad, bbmad, bebenatower, BENCHENA, biochemistali, blaiseid, blueservice, bpeti, brudariu, cellbhai, cellularry, CIMO, cimomario, CuLo, danau_ranau, deyblho, djanib, donito, Dr.Nabil, Dream Asia, drnele, eddel_0526, eduardo000, ejazkhan9, ElectronTelecom, etool30, farouk04, faycal_gsm, flash123, FullFlashPak, gsm4sp, gsmbac, gsmpuky, gsmsikar, hackgsm, hackwake, hichem18, hosanan, Ian, Imrankhan, inside-d-saul, irman santoso, ivanx, J@zz, johnmene, joker1222000, kaddafi, kamil-kulawiak@, KATOUE, kenawih, kishalayabiswas, kkio, ktbachkhoa, kyleann, leisoar, leveraged11, levsha, lezrey, Lucky star, lusomaco, M-taheri, Madeira, MAK_US1977, manju, marcosfranklin, MGT SOFTWARE, miananwar, miguel_john1975, mila aleksa, milkyctg, MisterX GSMFREE, Mithu, MNGASHNET, mobilegsm30, mobile_hotman, mohamdjwdee, mohamed183, motiam4, mp3, mr zakir, MR@NOKIA, nasermmx, nasirns, ndavid, neo_49, nicnec, Olegas, ottyone, phanthom2o4o, protons, raffazila, raie, Raja Com., rajabrotherscom, Random0285, raskee, ReyTech, Reza99, ringtons, RNC_EBM, ronkiton, ryumahon, saif@cellplus, sallupat, sanjeewa57, Saraz, Satyam321, senkron24, shahir4, shahzaadbutt, shakeelajmal, SHIJILFONOTLY, SiLver GSM, sky178, SkyMobile05, snsoftkiller, sunnyboy, szff, Techgsmnet, telecom2, tenderjuicyboy, trio1, tsarkh, Unlocker AL, Valera_VV, Vansy, wgmmmx, whalz, wikad1, wizardofwaz, wizz25, xiaoyuz, yacine ben, zakryia
Old 09-14-2008, 22:33   #26 (permalink)
Member: 4042
Thumbs up HWK Release 14/09/2008
Release Date: 14/09/2008
WARNING !!!
UFS_DCTxBB5 v2.0.8.0
RM-207,RM-235,RM-236,RM-257,RM-270,RM-277,RM-325,RM-328,RM-342,
RM-343,RM-345,RM-346,RM-352,RM-354,RM-355,RM-357,RM-358,RM-359,
RM-367,RM-378,RM-379,RM-386,RM-387,RM-396,RM-397,RM-400,RM-407,
RM-408,RM-409,RM-410,RM-411,RM-414,RM-416,RM-417,RM-418,RM-419,
RM-420,RM-422,RM-425,RM-436,RM-462
(6263,N78-1,N78-5,3555b,3555,3555c,6600f-1c6220c-1,N78-3,E66-1,E66-2,
E71-1,3600s,7610s,7610sb,E71-2,5610d-2,5610d-2b,6210s-1,7310cb,7310c,
6210s-5,6220c-5,6212c,6500c-5,6650d-1c,E71-3,6210s-1c,5320d-1,5220b,
5220,6600s-1c,5320,5320d-1b,5320,6210s-1b,E66-3,6124c-1,6122c,7210c,E71-5)
RH-116,RH-117,RH-118,RM-391,RM-392,RM-393,RM-394,RM-395
(7070,7070b,1681c,2760h,2680s,2680s-2b,1680c-2,1680c-2b)
3. New DCT4+ UNL versions support:
1200 (RH-99 v5.51,v5.53), 1200b (RH-100 v5.32)
1208 (RH-105 v5.51,v5.53), 1208b (RH-106 v4.00,v4.11,v5.23,v5.32)
1650 (RM-305 v5.32,v5.51,v5.53)
1680c-2,1680c-2b (RM-394,RM-395 v5.61,v5.63)
2610,2610b (RH-86,RH-87 v6.73,v7.10)
2630 (RM-298 v5.61)
2760 (RM-258 v4.20,v5.61), 2760b (RM-259 v4.20,v5.61)
2760h (RM-391 v5.45)
4. Fixed minor bugs.
5. New Flash Update Pack 8.36.2.35145
LG_GSM V 2.0.8.0
v 2.0.8.0 (HWK Required)
1. Added "FSct0" (Force Sector 0 Overwrite) Checkbox in
Infineon platform.
Use it for Frozen or blinking phones (KE800,..)
2. KP130, KP210, KP215, KP260, KP265 support added.
SAMs V 2.0.8.0
TRIDENT
S730i (DUNL,IM,FL)added.
B200,B300 DUNL and IM fixed.
Reserved Regions values revised and fixed.
MSL Repair enhanced, and added for following products:
C17x,C26x,C520,E84x,E90x,E95x,F21x,M300,M60x,P520, U10x,U30x,X82x
"Erase NOR" activated.
Enhanced 4CC protocol handler (fixed error on PC busy)
TRIDENT VISION
E21x,J60x fixed (INF,DUNL,IM)
M310 added (FL,CUNL)
OM(SYSOL)
A117,C288,M130L added (DUNL,IM,FL,SECT)
E746 bug fixed.
SWIFT
D780,D788(Duos2),D828E,E251,E251C,E258D,F110,G808E ,J210,L310,
P180,P200,P260,P850,P858,T309,T509,U908E,X700N (DUNL,FL,SECT)
F488E,J150 (FL,CUNL) Use 'Unlock E2P' to see Codes.
E35x,E37x,T809 DUNL, SECT and IM fixed.
E480,E488 bug in DUNL,SECT fixed.
D880-Duos flashing bug in 2.0.7.2 fixed.
X700 SECT fixed.
SWIFT-AEROFONE
B130 introduced(FL,CUNL) Use 'Unlock E2P' to see Codes.
QUALCOMM
A411,A412,A701,A706,A707,A711,A717,A727,A736,A737, A801,A817,
F330,F338,F400,F408,F480,F488,F490,F510,F550,F700, G400,G800,
G800B,G800L,G808,J200,J200L,J208,J630,J638,L170,L7 60,L760G,
L768,L810,L811,P910,P920,P940,P950,P960,T639,T819, U700,U700B,
U708,U800,U800F,U900,U900U,U908,V705,V706,V707,V70 8,Z150,Z170,
Z230,Z238,Z240,Z240E,Z248,Z310,Z360,Z368,Z400,Z540 ,Z548,Z560,
Z570,Z720,Z728,Z740,ZV40,ZV50,ZV60 introduced (FL,INF,REUL)
COMMON
Product Langpacks description added (Info and MCU-Open)
Note, real menu languages can differ from listed here,
for different models, firmware versions. Languages in
brackets is not mandatory for current Region.
SeDBx v2.0.8.0
DB2010
1. Added Support for: 36Brown, 49Brown
DB2012
1. Added Support for: 50Brown, 51Brown, 51Red, 53Red.
2. Added CID Upgrade.
DB2020
1. Added Support for: 49Brown.
2. Loaders Updated.
PNX5230
1. Added Support for: 49Brown, 52Brown.
2. Loaders Updated.
Odia.
www.sarasbox.co.uk
The Following 263 Users Say Thank You to Odia The Ultimate For This Useful Post:
℃man, >>PakFones<<, ***MADHUR***, -=MR_Gsm=-, ..::: Naveed :::.., ..::M-GSM::.., ..::UFUK26::.., .:::Dr. Cell:::., .::TR_LAZ::., .:HeRo:., .:JOAB:., .:RAGE:., 3G_phi., 65211355, 79mobile, : ronfreek :, @SorryNightStar, abderrazzek, abdo37, abdouunlok, abdulrahimkhan, abhishek aga, abl2910, abo amine, abu3131, ADD-GSM, Adityaram, ahmedzameer, ajazsha, alamgir80, ALEX_GSM, alfergany, alssalafiy, amralkareem, amr_ibrahim, anasalagha, andre128, andy_jpn, anhnhan2, antoniolcrd, appolo, arfono, armany99, artech2, arun1342, Audsky, awatm, ayhen42, ayubalikhan, azo_ja, ba7bou7a, bachirDraria, balLlroad, banalven1, bbmad, beli, beoption, beo_tech, bhama_shah, bilm25, biochemistali, blueservice, BOb3582003, boucettay, brokantor, brudariu, cao_nguyen6, cayton_l, celparts, cetech, CHAPRAN, cooloxf, corvinu, crstelefonia, curucel, cyberdamin, dambi12, damiao719, dawidoss, deab2001, deepakgarg, Deepakranasaria, Denny_boy, digimen, djanib, doktort, eddel_0526, EDY.PM, electroguezri, electro_mohamed, esbatu, Evimix, Fantoz, faycal_gsm, FEATURE GSM™, foo_men, foufou34, fr3nsis, Freshbol, galaxe44, geovanny78, giti2k, Gr8SightMan, grin77, gsm4sp, GsmOwar, gsmsupport, gsm_enggine, gunjan1, hackwake, Hady_e02@yahoo, haniey_x, harim_1981, HAROON's, Hasanudin, hasni_gsm, hichem18, hiep_hv, Hitec Wireless, hosanan, irmansantoso, J3soft, J@zz, jackfreedom, jeanbrume, jignesh269, joallo, joker1222000, juliamo, kabo tel, kalpesh.1978, kamel23b, kanapuza, kaspersk, kemo_nokia2000, kenawih, khanjee_zahid, kirojanev, kococos, kopsa2005, ldsaint, leisoar, Madeira, mahdiqaladza, makroud, Marek09, marekom, meisam, Mithu, mobilagy, mohamdjwdee, mohamed183, momayaz, Monty, MSCOMMUNICATION, mssn, multimedia, Nabil3H, naeem janjua, nano1, nanoy, nasirns, NAZTY, ndavid, nicnec, nishue, nnaeem11, notgood, oldsindbad, Olegas, omanmobile, ottyone, outlandier, pallumobile, parveen kumar, pcgeorge23, phanthom2o4o, PiRAtECh, ptnetwork, pupaji, radioone1, raffazila, raga3334, rajabrotherscom, rajeshbahri, rajtelecom, Ranamobiles, raselopu, raskee, Rastafari 69, raychevski, regis.rlc, rehmani, reyre.computer, ringtons, rishi1985, rizky_m, RNC_EBM, Rodrigo_c, rone, roshantelecom&s, Ros_GSM, rotelcam, ruwanruwan, sacin, saif@cellplus, Sakilist, salim_belka2002, sallupat, sam3578, samalik, sanjeewa57, sanku, sayedhas, senkron24, SERVITELCHILE, shadi, shahzad_786, sigis333, simomex, SmartFlasher™, sniperegypt, SO2YIA, soloymi, sonvtus, SpoOnx, ssatcom, subhdra, sumatera, sunnyarora, szff, tarik123456, tatospeed, tawanda, tayyabshah, tejasr, telcentro, tele-teknik, telecom2, tfcell, thanvantinh, thefoxes, thtgsm, tolski, tornado2008, trieubk, tsakis, TWISTER_FLasher, Umbabaraumba, Unlocker AL, venomhotboy, wakeil, waleedkhalid, willydewi, winnitsa, wizz25, Yashaka, yawarniazi, ymamine, yutthana, zahidnawaz, zeerik, ~AKSingh~
Old 01-14-2009, 06:56   #27 (permalink)
Member: 4042
Thumbs up HWK Release 14/01/2009
Release Date: 14/01/2009
WARNING !!!
UFS_DCTxBB5 v2.0.8.0a
1. Flash Fix added to installer
SAMs V 2.0.8.1
TRIDENT
CC01,P258,U600G added (DUNL,IM,FL)
TRIDENT VISION
B220,B310,B320,B518,B520,B528,J600G,J610,J618,M318 ,M620,M628
added (CUNL,FL)
L320 added (DUNL,IM,FL)
(Use [Reset MMI] if phone ask for password)
OM(SYSOL)
B110 added (DUNL,IM,FL,SECT)
SWIFT
D618,D980,E2510,F250L,F268,F278,G600G,G618,J770,J8 08E,L258,M150,
M200,M3200,M3510,S3600,T429,U708E,U808E added(DUNL,IM,FL,SECT)
D780,D788,D880,D888,D980 SLAVE support added (DUNL,IM,SECT)
J150 fixed (DUNL,IM,SECT)
IM Rebuild added and RAW TFS Read fixed for these models:
D618,D780,D788,D880,D888,D900i,D908i,D980,E200,E20 8,E250,
E250D,E250V,E256,E258,E258D,E251,E251C,E480,E488,E 590,E598,
E740,E747,E830,E838,E2510,F110,F250,F250L,F258,F26 8,F278,G600,
G608,G808E,G618,J150,J210,J700,J708,J770,J808E,L25 8,L310,L600,
L608,M150,M200,M610,M618,M3200,M3510,P180,P260,S36 00,T429,U708E,
U808E,U908E (Need power up phone with battery after IM done !)
SWIFT-AEROFONE
B130,B130S,B130T added (DUNL,IM,FL,SECT)
SWIFT-3G
B2700,J800,L700,L708 introduced (DUNL,FL,SECT,BT)
SKYWORKS
C100 - 'Not Released Yet' bug fixed.
QUALCOMM
F480G,F480H,M7500,M8800,S7330,U900F,U900G,U900K added(FL,INF,REUL)
Added QualComm mode support:
(*#QUAUSB# to enter QualComm mode, QC Debug Interface on USB)
(*#SAMUSB# to enter Samsung mode, QC Debug Interface on RJ45)
QCDI Info, NVM Read, RAM Read added.
UNLOCK and UNFREEZE introduced for these models:
F480x,L760x,U900x,Z240 (Use [QCDI Info] button to readout keys)
COMMON
Stop button added.
User interface localisation.
Samsung / Qualcomm USB Drivers can be downloaded here:-
http://rapidshare.com/files/19063817...SB_Drivers.zip
Update Client V 2.0.8.1
Fixed Exception errors on req-fbi process
!!!THERE IS NO NEED TO UPDATE YOUR HWK SINCE 2080 RELEASE IF ITS WORKING OK !!!
We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future.
Conditions:-
1. Only 1 contributer per language.
2. You must know how to use the software and what each function does.
3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required.
Odia.
www.sarasbox.co.uk
The Following 163 Users Say Thank You to Odia The Ultimate For This Useful Post:
***MADHUR***, *PROPHONE*, -=MR_Gsm=-, .::TR_LAZ::., 79mobile, @SorryNightStar, abdulrahimkhan, adilosse, Age_Gsm, ahmedraj, ahmedzameer, alamgir80, aleon, alfergany, aliazer, ambt, Amorphes, amr_ibrahim, ankupis, antoniolcrd, arektk, aribairam2008, ASK_ME, aslam870, assolimany, asson, Audsky, ayubalikhan, aziman, badism16, balLlroad, banalven1, barryiso, bebenatower, benito, beoption, beo_tech, biochemistali, blueservice, borce_razor, boucettay, cellbhai, crstelefonia, ct3im, CyberMCS, deechan83, digiphone, djanib, djlicks, doktormobil, drnele, eivoig, ELBORSAIEDY, eletrico, elkom, ersa, excelpass, fateh76dz, fawad85, Feda, FIRAT58, fretburner, gogon, gone_bdg, GRAFISCELL, gruja87, GSM-DOCTOR, gsmbun, gsmsupport, GSM_HACKING2003, gunjan1, hackgsm, hackwake, harisha g h, hery_andi, hoze!!!, HZZORY4GSM, irfan99, jayan_jayan, jeanbrume, jirenbin, JKKB, joallo, jr_buenaflor, k babu, kamalidroos, karikari, kemo_nokia2000, kenawih, kerug-bali, Kimanh_black, KMHON, krimmo, kumkon, lath123, Lharrie, lion4000, lutownica, masih455, max0066, maxieboy, mico, mizancoxr, mobil-centar, mohamdjwdee, mohamed183, mohanadmadi, moonfighter, morton1984, mr zakir, mti_gsm, nasirns, NAZTY, ndavid, neoBIT666, newerno, nicnec, notgood, onlylove, ottyone, pat_mat, phanthom2o4o, Pungkas, pusulateknik, radioone1, rajan nishchal, raychevski, rmarconcini, Rodrigo_c, rone, Ros_GSM, ruchito, saidgsm@gsm, saif@cellplus, sakisager, samalik, Saraz, sasan14, schemu, sdimitris, sebY7676, servisoft, Shiroko, SilentHawk, SkyMobile05, sman234, sumatera, tarana3263635, tetrasquel, textusadiktus, TH Mobile, trio1, turca, Umbabaraumba, unlock boy, vertz, winnitsa, wizz25, xiaoyuz, yarra, zahidnawaz, zeeshankhadim
Old 02-10-2009, 03:36   #28 (permalink)
Member: 4042
Thumbs up HWK Release 10/02/2009
Release Date: 10/02/2009
WARNING !!!
UFS_DCTxBB5 v2.0.8.2
1. Flash Update Pack problems Fixed.
2. New BB5 products:
RM-247,RM-297,RM-333,RM-334,RM-335,RM-348,RM-349,RM-350,RM-356,
RM-398,RM-399,RM-415,RM-427,RM-428,RM-429,RM-437,RM-449,RM-450,
RM-472,RM-493,RM-494
(N96-1,N96-5,N85-1,N85-3,N85-5,N79-1,N79-3,N79-5,5800d-1,7510a,7510a-b,
6600s,5800,5800,3610a,E63-1,E63-2,E63-3,N96-3,E71-5,E66-5)
3. DC4 Flash Chip 0020883C Fixed.
4. New DCT4 products:
RH-111,RH-112,RH-113,RM-438,RM-439,RM-490,RM-500
(1202-2,1202-2b,7100s-2,7100s-2b,1680c-2b,2680s-2b)
5. New DCT4+ UNL versions support:
1200(RH-99 v5.71,v5.80) 1202(RH-112 v2.80) 1208(RH-105 v5.71,v5.80)
1650(RM-305 v5.71,v5.80)
6. User interface localisation.
LG_GSM V 2.0.8.2
1. Infineon GB100,GB105,GB106,KG285,KG288,KP100,KP105,KP106,KP 107
support added. (BIN bundle files open as FLS)
2. Read/Write for Infineon EGOLD Voice added.
3. Auto Backup for Infineon EGOLD Voice added.
4. ADI KF240, KF300
support added. (BIN bundle files open as Code)
Cable as for KP130,KP210,KP260
5. QualComm models introduced.
SAMs V 2.0.8.2
TRIDENT
B270 added (DUNL,IM,FL)
TRIDENT VISION
J610 MSL corrected (DUNL,IM)
E215L,M320L added (CUNL,FL)
OM(SYSOL)
M140 added (DUNL,IM,FL,SECT)
SWIFT
J706,L708E added (DUNL,IM,FL,SECT)
SWIFT-AEROFONE
B130,B130S,B130T fixed flashing for HW 0.600
QUALCOMM
ENUMERATION NOT EXIST: 20 bug fixed (up to COM256 supported)
Fixed flashing for OEMSBL V5.32 and higher (M7500,M8800)
UNLOCK and UNFREEZE added for these models:
F480F,M7500(******),M8800(Pixon),U700,U700B,U708,U 800,U800F
S7220,S7350 added.
Conditions:-
Odia.
www.sarasbox.co.uk
The Following 76 Users Say Thank You to Odia The Ultimate For This Useful Post:
..::AppleLinks::.., ..::M-GSM::.., abdulrahimkhan, adilosse, ahmedzameer, ALEXIS_089, alfergany, aljawal, andastar, anupob, arfono, arthur1964, assolimany, Audsky, ayubalikhan, ba7bou7a, bbmad, beoption, blueservice, bnasirbutt, bogdanrex0, cellbhai, CellWorm, cheong966, dancameo2k, delax2006, Denozaur, deyblho, dienson, digiphone, dlasz, euluscell, Evimix, flasdaft, galin_milcov, hassenmobile, ikram tabassum1, ilieff, jamal2010, k babu, karikari, kenawih, kunene, meddec, mohamdjwdee, mohamed183, morton1984, mr.6630, mr.tatoo, nasirns, nazar2008, newfoundghori, nicnec, oric, phanthom2o4o, PK2, raffazila, rana_sab, rayvee, richardquaker, rizky_m, Rodrigo_c, rone, samalik, SAN INFOTECH, skidnix, sniperegypt, textusadiktus, toptro, Valera_VV, Vero, wajda3, webshawk, yawarniazi, zahidnawaz, ZIYAAD STRYKER
Old 03-21-2009, 14:53   #29 (permalink)
Member: 4042
Thumbs up HWK Release 21/03/2009
Release Date: 21/03/2009
WARNING !!!
ATRz v2.0.8.3
1. Fixed clipboard issue on Vista.
UFS_DCTxBB5 v2.0.8.3
1. New BB5 products: RM-495,RM-496 (5130c-2,5130c-2b)
2. New DCT4+ products: RH-121,RH-122 (1661-2b,1661-2)
1202-2,1202-2b (RH-111,RH-112 v3.00, v3.10)
1661-2 (RH-122 v3.10)
2610,2610b (RH-86,RH-87 v7.11)
2680s-2,2680s-2b (RM-392,RM-393 v4.56, v4.91)
5000d-2,5000d-2b (RH-362,RH-363 v3.50, v3.54)
7070d-2 (RH-116 v6.20)
4. Simlock status detail info for DCT4 and BB5 models added.
5. Fixed clipboard issue on Vista.
LG_GSM V 2.0.8.3
1. BIN (TotalBin) files support added for ADI models.
2. ADI KP260, KP265 UNLOCK and REBUILD fixed.
3. ADI KP170, KP175 added, cable as for KP130,KP210,KP260
4. LGMDP NV2 format files support for QC NVM Write.
5. User interface localisation.
6. Fixed clipboard issue on Vista.
SAMs V 2.0.8.3
TRIDENT
C275L,C500L,C506,C510L,C516,E570L,U106 added (DUNL,IM,FL)
TRIDENT VISION
B520B,M310L added (CUNL,FL)
OM(SYSOL)
C145,C161,C168B,M140L added (DUNL,IM,FL,SECT)
SWIFT
C3610C,E200B,E230L,E251L,F270L,F275L,F480L,J700L,P 906,U900L
SWIFT-AEROFONE
B130L,E1110(Euro and Asia),E1110C,E1117,E1117L
Increased flashing speed.
QUALCOMM
G400L,M8800B,V820L added.
G400,G400F,G400L,Z150
COMMON
Conditions:-
Odia.
www.sarasbox.co.uk
Official SarasSoft Rapidshare Mirrors:-
http://rapidshare.com/users/VAY6Q3
The Following 92 Users Say Thank You to Odia The Ultimate For This Useful Post:
-=MR_Gsm=-, ..::AppleLinks::.., .:CARLO:., .:HeRo:., 6800, 786786, aashir, abdulrahimkhan, ahmedzameer, alamgir80, alayne, alfergany, arthur1964, bawuy, beoption, bilm25, biochemistali, blueservice, bnasirbutt, CellWorm, CxVj, dandash2010, danishrehmanzai, eletrico, faisal ch, faycal_gsm, feniks17, geti, gsm-forummaciel, gsmmama, Hady_e02@yahoo, hassenmobile, joallo, josuesoft, k babu, karikari, kenawih, Lgsaga, lusomaco, luyanda, maidung_mobile, masudtel, mgbhatti, mobelix, mobtelg, mohamed183, morton1984, Mr.ps_mobile, my toh, Nabil3H, nadson, nasirns, oric, parmo-ami, pat_mat, pepos, peter002, phanthom2o4o, ptnetwork, Pufi164, puluhwatu, raychevski, rayvee, RNC_EBM, robin25, sabby_singh, said4, Sakilist, Secgsm, Shiroko, sky178, sniperegypt, starhub, sumatera, svgasathik, TANGINGSIANG, tawanda, telecelula, trindade, vagala, Valera_VV, vertz, vicky_gateway, wgmmmx, wiss25, xiaoyuan, yawarniazi, yui, zahaf, zahidnawaz, zalp
Old 04-06-2009, 11:36   #30 (permalink)
Member: 4042
Thumbs up HWK Release 06/04/2009
Release Date: 06/04/2009
WARNING !!!
UFS_DCTxBB5 v2.0.8.4
1. Added info about flashed Certificates for BB5.
2. Corrected DCT4+ unlock error messages.
3. Find Product settings by VPL files.
4. New BB5 product RM-458 (6208c)
SAMs V 2.0.8.4
TRIDENT
B100M added (DUNL,IM,FL)
TRIDENT VISION
B310R added (CUNL,FL)
SWIFT-AEROFONE
E1070,E1100T,E1125 added (DUNL,IM,FL)
QUALCOMM
Increased Comms speed on RJ45 interface.
L810,L811
Conditions:-
Odia.
www.sarasbox.co.uk
The Following 89 Users Say Thank You to Odia The Ultimate For This Useful Post:
-=MR_Gsm=-, .::TR_LAZ::., 6800, ab media, abdulrahimkhan, ahmedzameer, alamgir80, aleon, alfergany, alituha, antoniolcrd, arfono, aribairam2008, ashokassag, ayubalikhan, banalven1, bbmad, blueservice, chokchai, connectingfun, deyblho, digiphone, Dizemizyh, djlicks, eddiea, fagamon, freedomqn, hoze!!!, IgorIgs, J@zz, julmars, kasner, kenawih, KhOliO, KhUaN, lusomaco, mahesh_patel361, manish1234, mario0383, MGT SOFTWARE, mohamed183, mohiddin, morton1984, mquimpanes, Mr.ps_mobile, mr.tatoo, MR@NOKIA, NadeemShahzad, Nadjombe, nasirns, nazar2008, nicnec, nongmobile, oric, phanthom2o4o, prins13, radioone1, ragguem76, raie, rajinder1978, rana_sab, raskee, Rastafari 69, rayvee, RNC_EBM, rone, rontekgsm, ruchito, sabby_singh, Sakilist, sandeephanda78, shaheen2005, simsim55, skidnix, sniperegypt, speedychak, sumatera, tayseer, tedyjohar, tele-teknik, turca, TWISTER_FLasher, udasisunil, ugurusta, Valentyn, WebSnake99, welking, yawarniazi, zahidnawaz
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 24 08-11-2006 15:29
Nokia 8850 v5.11 GSM Starter Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-30-2000 13:46
6130(nsk3) pic.hex ver: 4.11 wanted!!!! MODCHIPS Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-31-1999 04:05
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 09-25-1999 03:34
Menu 11 on NOKIA 6150? Rebel Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-13-1999 07:24
Page generated in 0.92107 seconds with 11 queries
