05-03-2007, 18:24 | #46 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Germany , Bavaria Age: 45
Member: 37125 Status: Offline Thanks Meter: 19 | The option RESET USER CODE doesn't work. The Box do anything and show all ok but the USER CODE isn't resetet. I found this problem on Nokia 6310i. After I calculated Mastercode with a other Problem , I could reset Usercode to 12345 back. Please HWK solve this bug , and by the way I would be cool If SARAS make a Mastercode Calculation on DCTx Software , like the Unlock Code Generator. THANKS |
05-03-2007, 20:36 | #49 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | 1110 and 1600 Unlocking Not Working Hi Mr. Odia! I have tried both 1110 and 1600 with 5.53 and 5.54 versions, but this update is also failed to unlock these two modles. Just want to ask that 1110 and 1600 are not ASIC2 types?????? If yes then your update features says that "Unlock ASIC2 Models" and its still not working. Realy Confused................................ yawarniazi |
05-03-2007, 21:17 | #50 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
I personally tested 3 version of 1110i mate, 5.50, 5.53 and 6.00, and all 3 versions work 100%! If needed i can provide beta test screenies of successful unlock! | |
05-04-2007, 04:34 | #54 (permalink) |
Crazy Poster Join Date: Jul 2006
Member: 308069 Status: Offline Thanks Meter: 0 | I download latest version of dctxbb5.tip 010407, i overwrite the original, but the bb5 list stills the same, in the UFSX section it says COMPOSED BY: AHMED SALMAN 01 ABRIL 2007, thats the only section that had changes. What i have to do? What im doing wrong? Im only overwirte dctxbb5.tip, i have to do something more? Thanks! |
05-04-2007, 05:50 | #55 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | Quote:
05-04-2007, 06:12 | #56 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: inside nokia tuning plant Age: 48
Member: 48980 Status: Offline Thanks Meter: 7 | Quote:
05-04-2007, 06:15 | #57 (permalink) | |
05-04-2007, 10:16 | #58 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | To @ODIA MCU Sw: V 5.53 20-07-06 RH-64 (c) NMP PPM Sw: V 5.53 20-07-06 RH-64 (c) NMP EE Prd.Cd: 0530030 Bpr.Cd: 0520754 Pro.Sn: KGP668559 HW : 0526 UEM : 1328 UPP : 8705 RFIC : 0500 DSP : P05w06.v34 LCD : SDI:LD184v89 IMEI : 354527-xx-xxxxxxxxxx SLconf: 226-10-00000000000 SLprof: 800000000000000-2 SLvar : 00003545270124377900 SLaux : 00023337 HwSig : E3BA3D1BDFDB5627 BoxId : 8C038C03FFFFFFFF Provider: Mobil Rom DIALOG;Romania #pw+ 454 317 076 255 123 +1# #pw+ 223 995 240 111 404 +2# #pw+ 853 801 377 110 415 +3# #pw+ 705 320 023 335 037 +4# #pw+ 303 366 726 105 071 +5# #pw+ 116 324 233 475 133 +6# #pw+ 052 493 472 076 107 +7# |
05-04-2007, 11:02 | #59 (permalink) | |
@ Lhick, 1110 tested and working, 1600 will try to get one today and make tests! | |
05-04-2007, 12:25 | #60 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | @GSMINTERNATIONAL, this capture was taken AFTER I made unlock, and you can se there is no "test equipment" , and it is still locked .................................................. .................... "6. Improved F-Bus polling, fixed "Bad Resp UFSx" after fatal error." Still exists.... |
HWK Release 18/08/2007 - Discussion | Odia The Ultimate | HWK | 211 | 04-21-2008 20:05 |
HWK Release 29/05/2007 - Discussion | Odia The Ultimate | HWK | 90 | 08-05-2007 07:39 |
HWK Release 23/05/2007 - Discussion | Odia The Ultimate | HWK | 83 | 06-10-2007 10:53 |
HWK Release 10/05/2007 - Discussion | Odia The Ultimate | HWK | 57 | 05-25-2007 01:09 |
HWK Release 14/05/2007 - Discussion | Odia The Ultimate | HWK | 91 | 05-17-2007 22:57 |
