05-10-2007, 14:34 | #91 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Pakistan Age: 44
Member: 240756 Status: Offline Thanks Meter: 86 | Problem not solve Quote:
05-11-2007, 06:26 | #93 (permalink) | |
Member: 240756 Status: Offline Thanks Meter: 86 | Re Hwk Update Quote:
if no result then i would try myself .thanx ur corporation. See this updated image of Hwk.is there anything wrong or succeessfull udate.this may help u.. Thanx | |
05-11-2007, 15:49 | #95 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
uninstall your old ufs suite and driver then install latest instaler http://forum.gsmhosting.com/vbb/show...3&postcount=14 install latest driver path- x/program files/saras soft/ufs/ufs_usb_driver then click update botton which marked in red then post log | |
05-12-2007, 06:01 | #96 (permalink) | |
Member: 240756 Status: Offline Thanks Meter: 86 | Quote:
in new windows xp.but same problem facing.I think this is not hwk problem which i understand this is ufsx device problem,bcz Hwk update client update the Hwk without any Error Successfully.and u also have seen in pic which i upload to u.Hid Ok,licence true,feature 000000.all is ok but in the end of connecting show this Error.So now then i will change ufs device.and then try and i will post he result. very thanx to u. | |
05-15-2007, 23:46 | #97 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 86 | Odia Need ur Help Now Plzzzzzzzzzzzz well how many days had gone now.and im trying to update my Hwk but always showing Error"Not authorised, use update tool" even updated many time successfully with Update Client.I did apply every thing Change pc,New Xp installed and New Hwk Exe and Driver.But still no luck.now im lost and tired.If Odia Help me i will very thankfull to him.now Odia the ultimate Can help me.i will wait his Response good solution. And i would like to thanx to TURNING POINT He Really help me. Plz Odia Take it serious my matter.Im in deep trouble Really. I really want to use new hwk Exe. Thanks In Adv... |
05-16-2007, 10:37 | #98 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
http://forum.gsmhosting.com/vbb/show...2&postcount=93 The HWK Status is 1 DL 9, this means the HWK is not updated, so when you click on "Start HWK Update >>" you must be getting some error and the process is not sucessful as you suggest. Also I see you thank TURNING POINT, this is indeed a good idea, I see him very helpful in this forum and his information is good and correct. Odia. | |
05-20-2007, 23:24 | #99 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 86 | Mr Odia The Ultimate Thank you Mr Odia to reply So what should i do to solve this problem Mr Odia.even u have seen my images which i uploaded.what do u sugest me to solve this problem,even that my HWK is Original?I will wait ur reply with helpfull solution. I can solve this problem by you.I will very thankfull to you Mr Odia the Ultimate plzzz Sir....... |
05-21-2007, 11:31 | #100 (permalink) | |
Odia. | |
05-31-2007, 21:12 | #101 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Cameroon Age: 51
Member: 163755 Status: Offline Thanks Meter: 126 | HWK updating probleme Good day. If someone could asiste me,pleas here ares my probles,i have original HWK that i order from powerflasher with all information about the box (user name and pasword) when i try to update it giving me this error Authentication stage error: Socket Error # 10054 When i was having those error i use UFS hwk standalone and none"emu" since then when i try to upgrade Upgrade log: ---------- HWK Update Client v 2.0.5.0 ---------- ---------- HWK upgrade started:8:52:47 PM ---------- -- Target Id : 62 CF 1 7 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.6 (c) SarasSoft 2005. -- UFSx S/N : 11xxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: POWER-FLASHER -- HWK NOT CONNECTED or DEAD -- HWK ERROR : 0010 -- Target Id : 62 CF 1 7 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.6 (c) SarasSoft 2005. -- UFSx S/N : 11xxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: POWER-FLASHER -- HWK NOT CONNECTED or DEAD -- HWK ERROR : 0010 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Access violation at address 004029CD in module 'UpdateClient.exe'. Read of address 00000014 Waiting Djouaka - |
06-01-2007, 10:07 | #102 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Try to run the update twice, e.g. start client, next, wait ..., if have the above error, click back and then next, if still have the same error, I think the HWK is really dead or your UFS has some fault on the 16 pin header. Odia. |
HWK Release 18/08/2007 - Discussion | Odia The Ultimate | HWK | 211 | 04-21-2008 20:05 |
HWK Release 29/05/2007 - Discussion | Odia The Ultimate | HWK | 90 | 08-05-2007 07:39 |
HWK Release 23/05/2007 - Discussion | Odia The Ultimate | HWK | 83 | 06-10-2007 10:53 |
HWK Release 10/05/2007 - Discussion | Odia The Ultimate | HWK | 57 | 05-25-2007 01:09 |
HWK Release 14/05/2007 - Discussion | Odia The Ultimate | HWK | 91 | 05-17-2007 22:57 |
