Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 08-29-2007, 10:12   #1 (permalink)
Member: 576395
Question hwk upgrade problems
helllo Guyz
can any body help me why my hwk not upgrade
here is log
______________________________________________
Upgrade log:
---------- HWK Update Client v 2.0.5.0 ----------
---------- HWK upgrade started:12:02:23 ----------
-- Target Id : 62 CF 1 7
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.6 (c) SarasSoft 2005.
-- UFSx S/N : *****
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: S-FLASHER
-- HWK ID : A1.04-PRO1-788*************
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Socket Error # 10054
Connection reset by peer.(An existing connection was forcibly closed by the remote host.)
Old 08-29-2007, 19:17   #2 (permalink)
Member: 17711
Please Read Faqqqqqqq!
Old 08-29-2007, 21:03   #3 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Arrow
May Be Some Problam with your Local ISP Try More Many Times your Prolam Will Be solve...
Or
Try to Update you HWK With Another ISP Am sure Prob Will 100% Solve Already Solve Many Times..!
Regards
Munna Bhai
Old 08-30-2007, 08:11   #4 (permalink)
Member: 576395
thx munna i will try?
Old 08-30-2007, 17:48   #5 (permalink)
Member: 576395
no result munna
same prob
Old 08-30-2007, 18:12   #6 (permalink)
Member: 17711
Please read FAQ at this section on HWK Upgrade
Old 08-31-2007, 08:37   #7 (permalink)
Member: 576395
many people say to read faq
14. Authentication stage error: Socket Error # 10054
TCP/IP connection to server from your PC is unstable. Please try to connect to internet via different internet provider. If you have no such possibility, please try to perform upgrade process several times until you get positive result.
__________________________________________________
above write i do but no result
Old 08-31-2007, 10:51   #8 (permalink)
Member: 17711
Upgrade server was offline. Now it is online. Please retry upgrade operation.
Old 08-31-2007, 11:12   #9 (permalink)
Member: 576395
ok i will check and post result thx
Old 08-31-2007, 11:20   #10 (permalink)
Member: 576395
Same prob
Upgrade log:
---------- HWK upgrade started:15:16:26 ----------
-- UFSx S/N : ******
-- Licence 5 : True
-- HWK ID : **************
Old 08-31-2007, 15:20   #11 (permalink)
Member: 17711
Have you tried to change internet provider? You can try to upgrade via GPRS for example.
Old 08-31-2007, 20:20   #12 (permalink)
Member: 576395
i do every thing but same result
actually i belong to Pakistan
so can any body tell me
whats about server of aisa
can its up or not?
Old 08-31-2007, 22:26   #13 (permalink)
Member: 17711
What server? What is AISA?
Old 09-01-2007, 04:25   #14 (permalink)
Member: 170531
can its up or not?
if some server block from supplier internet in your country ,that meaning all ppl in your country will have problems in updat hwk ,whitch internet you use? dialup or adsl?try change provider ineterent and alsow chaange your computer ,maybe your windows make block for that server for hwk.
good luck.
Old 09-01-2007, 04:35   #15 (permalink)
Member: 170531
some provider internet block a port and a ip ,i know in some country the port (8080) its work and another port no work .that do from governement for block some web or some server ,like who use media phone or media ring for call by net so block that port , maybe its not happen in your country ,all eurob country open all ports and maybe no block any server ,so master-mind think the server for updat hwk use is block from his provider internet in his country .
hwk upgrade problem PASSIONATE_BOYS HWK 2 08-29-2007 20:46
Hwk Upgrade Problem johnmene HWK 1 01-12-2007 09:55
HWK upgrade problem Javajohn HWK 1 11-10-2006 10:51
HWK upgrade problem elbas HWK 7 06-07-2006 08:07
Page generated in 0.34959 seconds with 11 queries
