12-20-2014, 21:17 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | HWK .. Win 7 64bit Driver Problem ! how are you all .. ?? hope you fine .. i have a problem with my UFS HWK box .. the problem is that i can't install the driver .. box only accept the new one which makes UFS Panel HANGS forever .. when i try to install the old one from "OLD" folder i get this message .. and there is an exclamation mark on the driver .. !! i've tried almost everything to fix that problem .. but i couldn't .. !! so, if someone knows how to solve that problem .. pls help me .. thx in advance. |
12-21-2014, 13:24 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | You should not be seeing the hang issue on Win7 64, the old driver is not signed and only for use on WinXP. Provide a screenshot of your Device Manager, with the Universal Serial Controllers section expanded. |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
12-21-2014, 22:51 | #7 (permalink) |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Already tried that but same problem .. My HWK is the Micro one .. And i'm only facing this problem with Win7 64bit .. 32bit working fine .. Which means my HWK is not damaged. Sent from my iPhone 4S using Tapatalk. |
12-22-2014, 12:07 | #8 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | The only other thing I can suggest would be to try and find updated drivers for the OpenHCD Host Controllers. |
