09-18-2008, 07:04 | #3 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | here is link for 2nd pc. http://www.2shared.com/file/3948411/...ions_2080.html |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
09-18-2008, 10:40 | #5 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | But there is warning message: All OK, not necessary to Update HWK ! You Will Loose a Server Log, Proceed Anyway? What it means - loose server log? BTW: solution of Shakeel_pattoki working well. |
09-18-2008, 10:50 | #6 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | here is your solution.no need for searching. http://www.2shared.com/file/3948411/...ions_2080.html |
09-19-2008, 13:50 | #7 (permalink) |
Junior Member Join Date: Jan 2004 Age: 48
Member: 50557 Status: Offline Thanks Meter: 5 | mine one use in 2 pc is ok,when try to use 3rd pc use update client it say login fail, so try reg patch then still the same but can install hwk 2.08 then connect Dctx bb5 ,error pop up"unxperted......error 20"so i use back to the other 1pc oh.no it came out same problem any solution? |
09-19-2008, 14:03 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Note: Use 2070 for generating .req file and 2080 for updating. | |
