Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 07-06-2008, 19:48   #1 (permalink)
Member: 436596
install not authorized
this error apears when i want to install hwk suite setup 2.7
what shoud i do?
Old 07-06-2008, 19:56   #2 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Arrow
what shoud i do?
See Here:
http://forum.gsmhosting.com/vbb/showthread.php?t=518454
Munna.
Old 07-06-2008, 20:03   #3 (permalink)
pupaji's Avatar
Member: 734871
yaa.........its will be fine..
The Following User Says Thank You to pupaji For This Useful Post:
Old 07-07-2008, 08:58   #4 (permalink)
Member: 436596
i do that many times. but stiil problem exists.
i have installed hwk support suite again and again. but no difference.
but when i install version 3.04 tere is no error.
thank for your regards and sorry for my bad EN.
Old 07-07-2008, 09:22   #5 (permalink)
Member: 436596
here is the screen shot.
exactly it accured when i want to install main setup after installing support setup
The Following User Says Thank You to sabeti For This Useful Post:
Old 07-07-2008, 09:27   #6 (permalink)
pupaji's Avatar
Member: 734871
hi bro......use latast setup......will be fine.
Old 07-07-2008, 11:01   #7 (permalink)
cybr_blade's Avatar
Member: 465130
You need to do Update Client before you can install HWK Suite.
The Following User Says Thank You to cybr_blade For This Useful Post:
Old 07-08-2008, 14:56   #8 (permalink)
Member: 436596
everything become OK. thanks for your great helps
Old 09-22-2008, 14:47   #9 (permalink)
Member: 407247
Same problem but with 2.08
Hi I can not uninstall HWK Suite from Add/Remove list. It's give me same error as above.
please help. Can not even download HWK setup to run the clinte.
Old 09-23-2008, 07:48   #10 (permalink)
KARNVIR's Avatar
Member: 741065
solution of hwk installation
i all dear friends . am new here . i was facing this problem from sooo much time . after a while i found a solution of this problem . first of all uninstall all old softwares fromm pc related hwk . & restart pc & now install HWK_Support_Suite_Setup_v02.08.000 get here.
& install drivers from C:\Program Files\SarasSoft\UFS\UFS_USB_Driver. & connect ur pc to internet & update ur hwk with hwk update client 2.8. when ur hwk will successfuly updated then install HWK_Suite_Setup_v02.08.000 get here.
now ur installaion will complete easily. if u face any problem u can call me on +919417617110
The Following User Says Thank You to KARNVIR For This Useful Post:
Solution for "Key file not authorized! please contact support" Enter HERE : The_Gorr Redbox 124 03-20-2012 14:53
W220 not authorized Arthur100 Motorola Hardware Repair Section 8 09-19-2008 07:49
You are not authorized to acces this page. ! Kanwalgee FuriouS II 1 10-11-2005 02:51
You are not authorized to acces this page. ! UAV FuriouS II 4 06-30-2005 13:51
The operator will not authorize a clone in a network swinaky Sim Cloning and Scaning 0 05-11-2005 14:16
Page generated in 0.32026 seconds with 12 queries
