j700i samsung e2p error pls help me smasung j700i e2p error ..... Software: J700iVJIE2 Hardware: REV1.0 Regions : Brazil Language: en,es,pt Release : 2009 May Rev: 2 MSL Active Error in S/N Info E2P File: J700i_E2P.bin MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000014, Samsung KAP29VG00M [NAND 256M] E2P IMEI Patched Ok: 352450-03-142672-0 File CRC: 0x582253B9 Bad Chck: 0x40, 0x13C015D E2P Write Failed, at: 0x01E80000 |
what was the main problem of ur handset.why u try to write e2p????? post main reason with full of details.then want help |
mobile prob is fust falch aafatr imei is ???????? pls help me |
full flash your phone and write good e2p file. |
full flach is ok bat e2p not be write ..pls help me |
Ok, i think that you can try to LOWER the SPEED that you are using to write EEProm. Just change the speed to lowest possible. |
i have same problem with c5212 i tryed all spead cable is ok please help |
