Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 02-05-2007, 15:44   #1 (permalink)
Member: 11208
Kg220 unlock failed with HWK?
Hi.
I used 24 pin cable whcih came with original HWK. but it says no response from target. I tried with and without baterrey.
I installed ver 3.04
So what is the problemm?
Can someone share schematics for 24 cable?
Thank you for attention
Old 02-05-2007, 15:57   #2 (permalink)
Member: 78731
phone conector is ok ?? "water" for board
Old 02-05-2007, 17:12   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
this phone takes a long press. i got success after lots of tries. so keep on trying and 1 more thing long press with battery
Old 02-05-2007, 17:13   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
this phone takes a long press power button. i got success after lots of tries. so keep on trying and 1 more thing long press with battery
Old 02-05-2007, 19:10   #5 (permalink)
Member: 11208
deepakha
I don't know connector good or not.
New UFS is bought last week.
So do you mean I need to press "power button" for long while with bat?
In another thread I read that it work without bat.
Old 02-06-2007, 06:13   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
cant say bro it worked for me. but that was only one piece.u can try my way or other way main thing is u should get ur work done. best of luck
Old 02-09-2007, 13:12   #7 (permalink)
Member: 11208
Do you mean press red button for power on?
I hold this for long time.
Still same.
What could be problemm.
I am not familliar with lg unlocking.
Old 02-09-2007, 14:47   #8 (permalink)
::Yasir::'s Avatar
Member: 47281
May be u have 2 cables in UFS pack! Try with both. It will unlock. and don't worry to rebuild IMEI because phone might not power up1!!
Old 02-09-2007, 14:52   #9 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
what u mean by rebuild imei and phone will not power up.
i m using original hwk & never faced such problem
Old 02-09-2007, 17:58   #10 (permalink)
Member: 118601
i have unlock many of this phone without problem. are you sure that your cable is ok. if yes, just select the low speed. because fatest speed can't unlock this phone. do it and boot the phone using the soft all will be ok 100% working
Old 02-10-2007, 06:34   #11 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
yes exactly i always select 115200 to unlock and it worked
Old 02-11-2007, 22:33   #12 (permalink)
SM4RTBOY's Avatar
Member: 92326
enjoy ... kg 220 + no battery attached + 24 pin cable !
dont use battery in unlock process
so upen UFS make boot and attach cable w/o batt ! thats all
sm4rtboy
Old 02-13-2007, 22:34   #13 (permalink)
Member: 11208
Hi.
I tried at 115200 speed without baterey.
Still no luck. I kept pressing power on/off key for long time. Is there any thing I forgot? I loosing income.
any hint please?
Happy Valentine day to all.
Old 07-17-2007, 18:56   #14 (permalink)
Member: 179713
It works!!!!!
SM4RTBOY + deepakgarg are right !
1. remove bat
2. connect UFS
3. select Product: KG220
4. Change Baud: 115200
5. push BOOT
6. Connect your LG KG220
7. Press Red button (on/off) and hold a long time
8. when mobile is connected press UNLOCK
DONE.
Pozdro.
Old 12-29-2007, 17:32   #15 (permalink)
master_t2's Avatar
Member: 321796
Originally Posted by bosseq View Post
It works!!!!!
1. remove bat
2. connect UFS
5. push BOOT
DONE.
Pozdro.
Yes......................correct solution.thanks a lottttttttttttttttttttttt
6500c flashing failed with HWK milkyctg HWK 5 10-25-2009 19:27
Z610i unlock failed with A1 java unlocker ABDELFATTAH NET Cruiser Suite 2 06-13-2008 16:36
Unlocking k750i with hwk iceman1345234328 HWK 3 08-06-2005 18:53
Page generated in 0.89985 seconds with 11 queries
