09-28-2010, 14:53 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | KG800 need flash file to repair i flashed KG800 (i think classic not pink vesion but colour is dard red) i used this files: KG800P64-EEU-V10c-XXX-XX_MAY_23_2006_Code_Data.bif (16 777 224) KG800P64-EEU-V10c-XXX-XX_MAY_23_2006_Alchemy_Data.bif (16 777 224) during flash i set SKIP calibration data, i have saved (32776kb) file with calibration after flash phone dead, no reaction but booting without any problem. PLEASE! i need good flash files to repair KG800. glad if this could be with polish lang but anykind of files to repair are welcome. |
09-29-2010, 14:57 | #2 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | anybody can't send me his KG800 flash files for anykind of language ? this is KG800 info from usf: Boot Ok, FL_ID : 98 00 4A [TOSHIBA] maybe it's PINK version? Last edited by PSG; 09-29-2010 at 15:06. |
09-29-2010, 20:09 | #3 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | i have now seevral flash files in MOT format but stil kg800 not powerON after flash. i tried: KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 KG800P64-EEU-V10k-XXX-XX SEP 07 2007 702 KG800P64-EUR-V10l-XXX-XX SEP 28 2007 702+1 KG800P64FL-385-V10c-219-02 SEP 11 2007 702 KG800P64FL-48-V10d-260-01 OCT 17 2007 702 and flashing went OK but phone don't powerON please advice what i'm making wrong ? |
09-29-2010, 22:59 | #5 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | yes i flashed calibration file (32 776kb) several times but kg800 still not powerON calibration data was saved during unlock process after unlock i made flashing to make polish lang and after this phone can't powerON Boot Ok, FL_ID : 98 00 4A [TOSHIBA] BaudRate Set to: 921600 IMEI: 352638-01-xxxxxxx-x MOT Format File, Converting to BIF Region: 1, 0x01000000-0x018987CB, Length: 9013196 bytes Processed: 563325 record(s) Saved as 1_KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 CodeData.bif Write [01000000-01001FFF] Skipped Write [01002000-01003FFF] Skipped Write [01004000-01005FFF] Skipped Write [01006000-01007FFF] Skipped Write [01000000-018987CB] Done, Time: 02:26 Erase [04800000-04FFFFFF] Done, Time: 00:37 MOT Format File, Converting to BIF Region: 1, 0x04010000-0x04E86607, Length: 15164936 bytes Processed: 947809 record(s) Saved as 1_KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 AlchemyData.bif Write [04010000-04E86607] Done, Time: 04:06 Write [01000000-01007FFF] Done, Time: 00:00 |
09-29-2010, 23:19 | #7 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | if this could be battery or powerON swich problem phone should show charging when AC-charger is connected but there is no reaction on LCD. battery is now 3.92Volt this time i used BIF files made by software after last flashing from MOT files, and same no powerON Boot Ok, FL_ID : 98 00 4A [TOSHIBA] BaudRate Set to: 921600 IMEI: 352638-01-xxxxxx-x Write [01000000-01001FFF] Skipped Write [01002000-01003FFF] Skipped Write [01004000-01005FFF] Skipped Write [01006000-01007FFF] Skipped Write [01000000-018987CB] Done, Time: 02:27 Erase [04800000-04FFFFFF] Done, Time: 00:34 Write [04010000-04E86607] Done, Time: 04:06 - here's end of flashing Write [01000000-01007FFF] Done, Time: 00:00 - here's calibration wrote |
09-29-2010, 23:23 | #8 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | how to flash some kind of full flash files, BIG file for kg800 with all required data? maybe calibration backup (32 776kb) file made during unlocking procedure is bad. as i wrote before, i made unlock then check phone, there was no simlock so i made flash (skip calibration data was checked too) for flash i used: KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 CodeData.mot 26 476 282kb KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 AlchemyData.mot 44 547 022kb or files made by software from MOT (BIF files): 1_KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 CodeData.bif 9 013 204kb 1_KG800P64-EEU-V10j-XXX-XX JAN 18 2007 702 AlchemyData.bif 15 164 944kb i read someware what vygis said: PROBLEM: Some LG 2G phones don't power on after flashing with any flashfile SOLUTION: L''G phone have backup baterry for clock and etc.Sometimes,if phone was flashed with not correct flash file,this backup baterry keeps in phone RAM some ****,which not allows to power ON phone.Solution is one-to dissasemble phone,to find backup baterry and to short it or disconnect it for few minutes.If you can't find backup baterry on main PCB,you need to disconnect flex cable from flip for few minutes,because some LG phones have backup baterry in flip. Regards,Vygis'' _______________________________ i didn't short (+ and -) this battery because there is no battery on main PCB so i just remove this PCB for 10min outside phone Last edited by PSG; 09-29-2010 at 23:33. |
11-19-2010, 11:00 | #10 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Poland
Member: 189499 Status: Offline Thanks Meter: 16 | Hi, I have similar phone , dead after flash by hwk, I repaired tooday by z3x, download flash from gsmpl and flash with mot files , after flash full factory and all ok |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
