Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 03-31-2009, 21:43   #1 (permalink)
Member: 22284
kp 170 still locked after unlock why
i tried to unlock kp170 but still insert correct card even though you try to flash the unlock,What to do now doctors,Check pic below
Old 04-01-2009, 17:50   #2 (permalink)
Orane's Avatar
Member: 479336
Where did you get that KP130 cable from?
Old 04-01-2009, 18:17   #3 (permalink)
blaiseid's Avatar
Member: 37735
Re-buid your IMEI and try unlock again.
Check the label behind the phone.
Your serial number is corrupted.
Old 04-01-2009, 19:08   #4 (permalink)
Member: 22284
Nothing wrong with the imei number sir ,did you find it corrupt in the first pic.
About the cable ,here with from ufsx, check the picture
Old 04-01-2009, 20:14   #5 (permalink)
Orane's Avatar
Member: 479336
I have the Schematics already but i dont have the connector component i have RJ45 end, Diode and wire for cable but not the connector with the nine(9) pin
and usb doesnt have so much PINs and worse they are not in the same order has the cable require
Old 04-01-2009, 20:30   #6 (permalink)
Member: 22284
I used two kg 800 cables removed the pin and convert it to kp 130 cable
Old 04-01-2009, 21:14   #7 (permalink)
Orane's Avatar
Member: 479336
Thanks i will try and post my result. Thanks again Bro
Old 04-02-2009, 15:02   #8 (permalink)
blaiseid's Avatar
Member: 37735
Chi, your Imei is corrupted. as shown on your pic : 46323232323232-3,please rebuild it.
i know it s not prototype.
Old 04-02-2009, 19:21   #9 (permalink)
Member: 22284
When checked through *#06# everything is normal so why does it show this when i read from fone
Old 04-03-2009, 07:41   #10 (permalink)
ikram tabassum1's Avatar
Member: 681574
Sonork: 100.1614243
i have same problem when i boot phone phone give imei to 460----------
when i check imei *#06# imei is 35-----------------
i turn phone on and connect ufshwk select model and click info imei is 35---------------
pls help any body i have to kp170
Old 04-03-2009, 10:46   #11 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Please read full flash and upload to rapidshare or some other file hosting.
Odia.
Old 04-03-2009, 16:41   #12 (permalink)
Member: 681574
Sonork: 100.1614243
kp170 read full flash data link here
i read kp170 full flash data here is link
http://rapidshare.com/files/21689690...33652.rar.html
http://rapidshare.com/files/21689754...33706.rar.html
http://rapidshare.com/files/21689800...ALCH_.rar.html
http://rapidshare.com/files/21693774...CODE_.rar.html
Old 04-03-2009, 17:34   #13 (permalink)
blaiseid's Avatar
Member: 37735
I see, i think BUG in soft.
Old 04-04-2009, 19:29   #14 (permalink)
Member: 4042
Thank you for the files, please try with the attached ini file.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 04-05-2009, 23:18   #15 (permalink)
yui
yui's Avatar
Member: 7528
http://rapidshare.com/files/21787856...CODE_.rar.html
http://rapidshare.com/files/21787911...ALCH_.rar.html
http://rapidshare.com/files/21787947...11635.rar.html
http://rapidshare.com/files/21787971...11720.rar.html
here is files
unlock not work!!
thanks
kp 170 no signal after unlock evolutions LG 22 10-18-2012 08:28
kp 170 no signal after unlock shoaibrao FuriouS TeaM Products 15 03-02-2012 06:52
<<<<LG kp 170 still locked >>>>> Mounir Basic Micro-Box Software Support 13 09-01-2010 13:24
Z300 subset lock is still on after unlock, why? tekit.dk Samsung (USB-Smart) 0 04-27-2006 09:16
x70 still locked after unlock with griffin server gamdadda Griffin 3 05-29-2005 17:54
Page generated in 3.91686 seconds with 12 queries
