02-15-2007, 09:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | LG KG800 imei change problem.. need help pls. |
02-22-2007, 18:33 | #4 (permalink) |
Junior Member Join Date: Dec 2005
Member: 211019 Status: Offline Thanks Meter: 0 | Not sure if this can be done by HWK. Have read that the otp needs to be patched to bypass the imei check in a similair kind of way to how it's done on the sony ericsson phones but have not found any option in HWK to do this. If anyone has any info on how this can be done using HWK or of any utils to patch the flash file it would be appreciated. |
04-28-2007, 21:32 | #5 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | changed look at this screen shot, now i could not even get a kg800 to boot with my Rj45+usb cable, but i just pressed the imei, and box appeared, i entered new imei, WORKED, out the checksum with calcalator and hit write imei. NOW this phone was black listed, it is no longer, HWK changes the imei on kg800 (chocolate) |
The Following User Says Thank You to THE CLASH For This Useful Post: |
LG KU990 weak signal problem, need help pls!!! | gr8_viruz | LG Hardware Repair | 5 | 05-07-2009 12:28 |
how to LG kg800 imei change | cemalefendi | Infinity-Box | 0 | 11-15-2008 22:04 |
LG KG800 IMEI change fail | rajSE | VygisToolbox | 10 | 03-04-2007 20:08 |
LG KG800 imei change problem.. need help pls. | bakhshalvi007 | LG | 0 | 02-15-2007 09:18 |
VYGIS BOX not support for LG KG800 IMEI CHANGE? | lushuai | VygisToolbox | 7 | 02-06-2007 16:24 |
