03-28-2010, 07:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Iran
Member: 467118 Status: Offline Thanks Meter: 16 | M620 can't Restore MSL Data I have a problem M620 I'm flash With UST Pro with Format FFS & Repair Mode After Flashing cant not Resotre S/N And IMEI i'm Flashing the phone with the Safe Read File Flash , and imei and s/n OK But the phone is Hang yet i'm writing E2prom on this phone but the problem not slove Repair MSL Produce : Code: Using MSL S/N: RUHQA81792K 1st: 1st: 1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A) 2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0 FlashLoader Failed: Flsync Failed to Enter TEST Mode Code: Software: M620JPHL1 Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2008 December Rev: 1 Hardware: MP 0.700 IMEI: 358404-02-540477-5 BT Address: 002490-1caa47 MSL : Active MSL : FAILED 10 Locks: Error |
03-28-2010, 12:11 | #4 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Maybe then M620 is not supported for MSL repair, I need to check with Saras. Odia. | |
03-28-2010, 13:21 | #5 (permalink) |
Member: 467118 Status: Offline Thanks Meter: 16 | I 'm sure that my M620 cable is ok, because I flash the other M620 phone and repair MSL and repair serial after this problem. I erased the phone then flash it with read file but this problem not solved plz help me |
03-28-2010, 20:00 | #7 (permalink) |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | @ siyamack : yes ; it happened to me last weak i get 1 m620 work verygood but his owner want arabic ; i flach it with arabic fw but i wiched that i didn't bcz fone become somtimes hang somtimes restart .....& still same probleme however i reflach it with other version..?? |
03-28-2010, 22:35 | #8 (permalink) | |
Junior Member Join Date: Dec 2008 Location: In My Clothese Age: 40
Member: 935917 Status: Offline Sonork: 100.1622439 Thanks Meter: 2 | Quote:
And Then Repair MSL Test It! | |
03-29-2010, 17:49 | #11 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Are you sure this phone is M620 and not M620N? Odia. |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
03-30-2010, 12:04 | #15 (permalink) |
Member: 467118 Status: Offline Thanks Meter: 16 | Flash With M620JPIE1 : Code: Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x20011113, Length: 20756 bytes Region: 3, 0x20016000-0x200173BF, Length: 5056 bytes Region: 4, 0x2001E000-0x2001E09F, Length: 160 bytes Region: 5, 0x2003803C-0x20040F93, Length: 36696 bytes Region: 6, 0x20058000-0x20058037, Length: 56 bytes Region: 7, 0x20058138-0x2005C665, Length: 17710 bytes Region: 8, 0x20078000-0x20183CB3, Length: 1096884 bytes Region: 9, 0x20300000-0x21EB9323, Length: 29070116 bytes USB Boot Ok, McuId: 00030021, Ubl: 92D70133, 7-1.1 (Vision X122A) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s09.sre Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P Flashing NOR part... Write Done, 30247614 byte(s), Time: 03:32 FS Formated (FDI) FS Mounted (FDI) Files Count: 9 Writing File: /Def/Feelin' Like This - Cleo.mp3, 6983183 byte(s) Writing File: /JAVA/0000.jar, 91454 byte(s) Writing File: /JAVA/0000.jad, 314 byte(s) Writing File: /JAVA/0001.jar, 84697 byte(s) Writing File: /JAVA/0001.jad, 443 byte(s) Writing File: /JAVA/0002.jar, 78073 byte(s) Writing File: /JAVA/0002.jad, 428 byte(s) Writing File: /JAVA/0003.jar, 76736 byte(s) Writing File: /JAVA/0003.jad, 502 byte(s) FS Unmounted FS Write Done, 7318274 byte(s), Time: 03:08 Unlock Codes: #0111*00000000# [NET] #0121*00000000# [SUB] Code: Using MSL S/N: RUBS687887B USB Boot Ok, McuId: 00030021, Ubl: 92D7813B, 7-1.1 (Vision X122A) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s09.sre Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P Read Done, St: 0x23FE0000, 131072 byte(s), Time: 00:00, 0 Flashing NOR part... Write Done, 131088 byte(s), Time: 00:00 #0133*00000000# [SP] #0141*00000000# [SIM] #0149*38906899# [SIM] #0151*00000000# [AUTO] #0199*38906899# [FREEZE] MSL Data Read Ok, Use [Mobile Info] to Read Codes S/N : RUBS687887 Write IMEI : (With Cable Box) Code: Phone Must be with Battery and Powered On ! MSL : Active MSL : FAILED 10 IMEI: Error IMEI Write Error |
M620 can't Restore MSL Data | siyamack | UST Pro II | 2 | 03-30-2010 22:09 |
MSL data corrupt | iceburnmarko | SRS (Simlock Remote Server) | 5 | 03-20-2010 10:47 |
C140 MSL data analyse failed | kabiyal | UST Pro II | 1 | 02-05-2010 11:53 |
cant get msl data? | YASMOBILENEEDS | Ultimate-Sam | 4 | 12-22-2008 22:06 |
Z540 - Can't unlock MSL | Dengel | UST Pro II | 12 | 11-07-2006 19:48 |
